Kklx 250s
Old Mar 22, 2019 | 11:30 PM
Elnene5678's Avatar
Default Kklx 250s
I have a problem with my klx 250s it has spark compression and gas and it wont start
Old Mar 23, 2019 | 12:00 AM
durielk's Avatar
Push start it!
Old Mar 23, 2019 | 11:04 AM
Put in new spark plug if the one in there is a bit old. It may spark outside the engine, but inside may fail. I had that with my KLX650, wouldn't start unless bumped off. The plug electrodes were worn enough they wouldn't spark under the compression and all in the cylinder, but would spark like normal outside. Replaced plug and bingo!
Other question - has gas in tank, has gas in carb or has signs of gas mix in cylinder? Obviously if there isn't gas in the tank or not getting to the carb it won't start, but just asking to be sure what you mean by has gas. If your choke and pilot jet are plugged it will not start, You might bump it off, but it may stall at idle. Both signs you have crud in the choke and/or pilot sytem. Needs cleaned, probably best done by some shop or person with an ultrasonic cleaner or a carb washer.
Hope that helps.
Yahua2233
Nov 29, 2016 06:48 AM
mathiaswscott
KX250 & KX250F
Jan 16, 2014 05:39 AM
lukashanson21
KX250 & KX250F
Jul 1, 2012 06:49 PM
EMS_0525
Aug 5, 2010 12:05 PM
msuspartanbigten
Jun 14, 2007 05:44 PM
