Kickstarter Install w/pics
Old Sep 1, 2007 | 04:30 AM
Silver_Otter's Avatar
Default RE: Kickstarter Install w/pics
To hold the clutch, a penny between the clutch gear and the primary gear works good.
And then you have to lean to kick start it. Not that easy
________
Live sex
Old Sep 1, 2007 | 04:51 AM
justanotheradikt's Avatar
looks good...was wondering what all was involved in doin this.
how much did all of the stuff cost? and did you have to add some type of decompression switch, or is it still not that hard to kickstart it?
Old Sep 1, 2007 | 08:16 AM
sinkoman's Avatar
Anybody know if it's possible to ditch the starter motor altogether?
Old Sep 1, 2007 | 08:29 AM
MaverickAus's Avatar
ORIGINAL: justanotheradikt
With the right tecnique it's easy to kickstart
Old Sep 1, 2007 | 11:38 AM
ORIGINAL: sinkoman
Why wouldnt it be? You might need a new side cover where the starte hits the flywheel, if you take the starter off there would probably bea hole... a klx300 side cover would probably work.
Old Oct 17, 2007 | 08:22 PM
Thread fixed.
Nope the bike comes with decompression gizmo on the cam shafts......works like a champ and has saved me at least four times in bad situations......ALLMOLES SHOULD HAVE A KICKSTARTER
Old Oct 17, 2007 | 10:15 PM
klx250s_rider's Avatar
Yikes! I'll send you a plane ticket to put mine in!
Old Oct 17, 2007 | 10:16 PM
  #28
stellar_d's Avatar
Same here, probably be cheaper than a mechanic too!
Old Oct 17, 2007 | 10:36 PM
  #29
yoman1's Avatar
Nice write up
Did the beer come with the kit??
Old Oct 18, 2007 | 07:12 AM
  #30
tremor38's Avatar
Good to hear that, FM.
On latermodels of the KLX300, Kawiwent with different timing on the ACR to make thekick starting easier and take some stress off of the idle gear.Itmight be worthlooking for an exhaust cam on ebay or getting with Brewster at Thumpertalk about repositioning your ACR. I don't recall what year the change started but you can see when thePN changed on the KLX300part fich.
ORIGINAL: Finger Mullet
Thread fixed.
