Kickstarter Install w/pics
18 Attachment(s)
Here's some pics and limited instructions of me installing the kickstart kit on our little klx. Please note I'm used to working on outboards and other marine stuff...... this bike stuff is a little new to me. [/align][/align]Here's the kickstart kit out of the bag, notice all the washers and shims with no bags or part #s
Attachment 33011 No problem, nothing a beer and some calipers can't resolve Attachment 33012 Drain oil and coolant......remove water pump cover and associated impeller and the rear brake pedal with associated springs, don't forget to remove the clutch cable clip. Now remove right side cover and you should look like this. Attachment 33013 [/align][/align]Well at this point I wanted to install a part so I put on the ratchet gear kick guide....only 32 parts to go Attachment 33014 Unfortunately, the idle gear goes under the clutch, so the left side cover needs to be removed to hold flywheel while removing the clutch. First to go is the left side e-start gear gizmo (technical term) Attachment 33015 Now remove the whole left side cover......notice how big and nice our stator looks at least from my marine point of view. Attachment 33016 Now you're supposed to use Kawi special tool part no blah, blah......I used a $2.99 harbor freight pipe wrench along with my Utah skid plate to hold the fly wheel while I grabbed and removed the clutch. Attachment 33017[/align][/align]Clutch came off no problem, but it did take a little technique and patience... here's the removed right side clutch basket. Attachment 33018 Here's a pic of the right side after clutch removal. Attachment 33019 Ok, now I started to assemble the kickstarter itself.......make sure ya line up the indent on the shaft spline with the indent on the ratchet gear, hope you can see it in the pic. https://img.photobucket.com/albums/v...t/DSC01014.jpg Here's another view of the kickstart shaft, notice I'm getting low on parts Attachment 33020 Now install the Idle Gear....no biggie just a circle clip and shims. Attachment 33021 Slide in the kickstart shaft and Tension the spring 3/4 revolution counter clockwise so it locks in the engine case with tension. Attachment 33022 Reinstall clutch Attachment 33023[/align][/align]Put left side cover back on Attachment 33024 Tighten up and finish the left side Attachment 33025 Damn, with the kickstarter shaft I couldn't get the right side cover on due to the foot peg placement...... and after all this I gotta take off the skid plate to take off the foot peg See Attachment 33026[/align][/align]Ok, footpeg and skid plate off Attachment 33027[/align][/align]Hey, I think I spy a kickstarter Attachment 33028 [/align] |
RE: Kickstarter Install w/pics
No thanks, I'm not that good.;)
All done.....post and critique away. :D
Very, very nice work!
One comment that will probably make you want to throw darts at my picture though.... If you put the bike in gear, deflate the rear tire, stick a short piece of 2x4 between thetireand foreward part of theswingarm then re-inflate the tire (not fully), youcankeep everything from turningwithouthaving to pull the left cover and find a strap wrench. Your way was more proper, but I'm just saying.... ORIGINAL: Finger Mullet ORIGINAL: deej No thanks, I'm not that good.;) Edit: Ok I'm done critique and post away http://floridasportsman.com/art/jester.gif |
Great work, Finger Mullet, and nice photos. Now we know exactly what to expect. Thanks!
Awesome! Lemme ship my bike to you to put mine on:D
I'd like the kick start for a back up... foolish that its not on there! |
I am TOTALLY IMPRESSED!!
Nice job man!!!!! |
BTW, when the right side cover is off like that, its always a good idea to clean the oil screen, since that's usually the only time you have access to it. Looks like it slides out just below the clutch basket in your photos.
Sticking a gear inbetween the primary gear & the gear on the clutch basket would accomplish the same thing as holding the flywheel, but I dont see how either would hold the clutch nut still when trying to remove it or tighten it. There must have been enough grab in the clutch to hold everything still for you.
Im thinking back to when I rebuilt my RM 125 engine & had to put that nut on/off with an air impact because I could not hold it still. Even if I locked the outer basket & fiiber plates, the inner basket & steel plates still spun when turning the nut.[sm=dontgetit.gif] Nice writeup, thanks for all the info & trailblazing. I think if you took the clutch apart then had the tool to hold the inner basket removiung the other side covers would not be necessary? |
