K&N Crank Case Filter
Old Sep 2, 2006 | 09:37 PM
Default RE: K&N Crank Case Filter
Oh, don't forget to use one of those Help caps to cap off your airbox vent, otherwise you will be sucking dirty air directly into your carb, bypassing the filter - not good!
Old Sep 2, 2006 | 09:38 PM
jsac's Avatar
thanks for the pics.. another mod added to the list come winter time. LOL
i was thinkin about plcement for the filter tho... i might try routing the line back into the airbox through the 2nd snorkle once i hack the airbox lid... dont know if its feasible or not but ill check it out when the time comes...
thanks again.
Old Sep 2, 2006 | 10:05 PM
Oh, another advantage is that if you plan on doing Marty's PCV mod, you could find a PCV that you could use to just replace the coupler with and that would be a quick and simple install if you've already done this one, or you could do them both easily at the same time. Just a thought.
Old Sep 2, 2006 | 10:36 PM
Bad Bear's Avatar
Great Job Brian I will be doing mine soon as it comes in . That should stay dry enough up there
Thanks for the Pics I will post mine when I get them .
Old Sep 3, 2006 | 12:20 AM
LordVngr's Avatar
I'm a little confused. If you do this mode then you Dont have to drill out the airbox hole to 3/8 right. This negates that.
Thanks
LV
Old Sep 3, 2006 | 12:21 AM
jsac's Avatar
correct
incabiker
Feb 10, 2016 12:35 AM
NavKLX
Feb 20, 2008 02:13 PM
KLXrider44
Mar 24, 2006 04:53 AM
KLXrider44
Mar 23, 2006 08:42 PM
