Jet kit installed, now it bogs at bit
2006 klx250s. Installed the DJ Kit (128 Main, 4th Notch, 2 1/2 turns, slide drilled, washers used, sea level, stock exhaust, snorkel pulled) and now it runs great on the open road. However on the technical trails when I am just putting around in first, it seems to bog a bit, like it loading up. If I rev the engine a bit, it clears out. Any thoughts?
You mention "washers used". I would hope you don't have washers under your needle clip as that will richen things up even more so. Drop the needle a click and loose the washers (if you've got them under the needle clip). That would probalby solve your low speed bogging. With the stock exhaust system you're probably large on the main jet also.
