Ims tank.
Old Feb 17, 2014 | 03:19 PM
tb865's Avatar
Default Ims tank.
I have a 09 klx250s I was considering the ims tank. How does it fit? And I know the petcock is bolted to the frame. Does it have a fitting that's bolt to the tank?
Old Feb 17, 2014 | 03:54 PM
NorCalKLX's Avatar
The petcock has two hoses that go to the tank, you just transfer the fittings and the hoses connect right up. Everything is included to make the tank work. Just take your time, fitment is hit or miss but that seems to be the case with any plastic tank. I'm satisfied with mine.
Old Feb 17, 2014 | 04:26 PM
Brieninsac's Avatar
Ya, like NorCal said fitment can be a problem. But with enough wiggling it will fit. Also, be careful when tightening the bolts to the tank, they can easily strip.
Old Feb 17, 2014 | 08:25 PM
flatwoods's Avatar
Default ims tank
if you can put the tank in the sun (i know its winter) put it on a heat register it well make fitting much easier if the tank is warm, that extra gallon of gas is wonderful.
bmwhd
May 31, 2017 05:06 PM
bmwhd
Aug 27, 2006 04:36 AM
954ken
Jun 13, 2006 12:24 AM
Nobrakes
Apr 10, 2006 02:44 AM
bmwhd
Mar 15, 2006 11:54 PM
