HELP WITH ROAD TIRES
Old May 31, 2007 | 09:37 PM
mnmadness's Avatar
Default RE: HELP WITH ROAD TIRES
hey divodave, what kind of rear wheel did you pick up? 250, 300? I was trying to compare hub and wheel part numbers to pick up a spare set of wheelsand no luck ( at least on a reasonable budget)
Old Jun 1, 2007 | 02:28 AM
2k1w=no$'s Avatar
I belive that the klx250, klx300, and the kdx200 have the same rear hub. I have heard that the klx300 front hub will fit, but the speedo drive is probably different. Note that the speedo will be way off anyways if you use the stock hub with a 17in. rim unless you could source d-tracker parts for it.
olderthandirt
May 3, 2009 07:17 PM
ChewyR
Dec 14, 2008 04:49 AM
Roadrage
Ninja ZX-10R
Apr 9, 2008 07:55 PM
aszrael1266
Aug 15, 2007 05:13 PM
