Help me get this monster performing optimal!
Old Feb 8, 2016 | 09:09 PM
Klxster's Avatar
Lidless is the whole key - if offers the breathing a performance exhaust system or slipon needs to get-er-done... But running lidless requires custom fueling setups.
Old Feb 8, 2016 | 09:17 PM
2006KLX250S's Avatar
Oh, one other thing. My klx is a 2006.. that DJ kit 2152 is for 09-15. Will it work or is the carb different? Mine's a Keihin CVK 34, they list the 09s as a CVK34 but not sure if it's all the same..
Old Feb 8, 2016 | 09:31 PM
Klxster's Avatar
Call DynoJet for that - 800-992-4993
Old Feb 8, 2016 | 09:32 PM
Klxster's Avatar
But they are all CVK34's..
Old Feb 8, 2016 | 10:55 PM
Custom fueling setups as in jetting and changing the needle in the carb? Or like a fuel filter? Sorry I'm new to bikes
Old Feb 8, 2016 | 11:44 PM
Klxster's Avatar
"Custom fueling setups as in jetting and changing the needle in the carb?"
Yes, and I did the dyno tuning to find what works best with lidless + slipon - see the link below, in my sig line, the one with DGR..
I am running the MCM but the setup works with stock cam timing as well - Compared to my bike, you will not have as much TRQ(therefore HP) below about 6.5k - but you MAY have more TRQ/HP than my bike somewhere above 6.5k, with stock cam timings..
EDIT 12/16: Latest Dyno testing indicates that stock slide spring should be used if running non-MCM.
Old Feb 9, 2016 | 02:14 AM
That's a sweet thread.. But is that jet kit and main going to just give me high RPM power? Because I use a lot of low end torque when I ride. I usually only use the high RPM for steep hill climbs. Otherwise I like to lug it up hills in higher gears, or have torque available to get over logs and rocks without having to pin it.
Old Feb 9, 2016 | 05:15 AM
Klxster's Avatar
Ah, Torque curves are determined by things other than jet kits.. Obviously you can kill your TRQ/HP with improper fueling (less than optimal carb setups) ...
140/2N on the 2152 kit will simply give you proper fueling for your bike(FMF slipon + lidless) which means you will get all the TRQ and HP your engine + mods can make..
Old Feb 9, 2016 | 05:43 AM
Klxster's Avatar
Now there is a unique situation that will confuse you once you've successfully done the carb setup - maybe I can help you to avoid it - for the first few rides, run it exactly as you always have.. Keep the revs below 7k and feel the increase in low-mid power and throttle response in the range that you normally use off road to "lug it up hills"... Once you feel that increase, find a long straight or long hill, snap and hold WOT from 6-7k and HANG ON! Let it rip to at least 9.5k..
The upper end (with the 140/2N setup) is now fully awakened and the incease there overshadows the gains down lower..
Old Feb 9, 2016 | 11:51 AM
Ok, so here's the dilemma.. I bought the bike and it had a dyno kit already installed. But I'm not sure which one. I took it apart and he had a 132 main jet in there. Could very well be that kit you told me to get, I just dont know how to tell the needle, washers, and spring from stock. And I don't even know what the clip is.
My bike shop wants $84 for that kit. Im in Canada, so that seems like it'll be the cheapest price for me. The DJ140 main jet is only $4. So I'm tempted to just get the jet and save a ****load of money on parts I may already have installed...
If I took pics of the parts in my carb, with measurements, and posted, could you tell if they are from the correct kit? I do know the needle has one washer on it, in the 3rd position.
