Handguards question
Old Apr 10, 2010 | 01:17 PM
bweekley's Avatar
I installed the rallys on my SF, it comes down to having tools for the job. I used a hack saw to cut the throttle tube and rubber grip ends, then broke out the compress and grinder to remove the 3 tack welds on the weights. I then had to remove 2/3 of the **** on the clutch. it was time consuming but nothing major, I think and hour and a half and I was done.
Old Apr 10, 2010 | 04:37 PM
This = vibes.
This is smooth.....Right Finger? LOL
If that top pic is an lc4 like mine
You are absolutely correct ..... the klx, even with the 351 is smooooth as silk.
When I first bought my Adventure I thought I was never going to get used to the handlebar vibes .... its really over the top at first. I even changed my gearing not based upon off road riding criteria, but rather so that highway speeds (70 mph) would not be in that 5.2 k rpm range of vibrating madness. Higher and lower rpms are fine, well mostly.
I Imm.m UssEddD tO Ttthhe VvviiBrrations Now
Oh, my klx has Moose Raptor Bend Bars and Moose Bark Busters, easy install and about as high as one could go with the stock cables, very happy with them and I have hit quite a few trees, no problems in over three years.
Old Apr 10, 2010 | 06:30 PM
scottma978's Avatar
I also thought the hand guards were a huge pain in the ***...had I known, I would have bought some aftermarket bars at the same time. I didn't want to trim my bars any as I tend to hold my hands out close to the end of the bars. I drilled and tapped one side, and by the time I finished that side (my tap was a bit dull) I said F-this , glued my new grips on and called it a day...lol. If anyone is interested in a brand new pair of Moose Racing hand guards still in the packaging, let me know! scottma978@yahoo.com. Thanks
Old Apr 11, 2010 | 01:03 AM
ol'klx-er's Avatar
Don't give up now, you're 1/2 way there. Just cool off, maybe invest in another tap, finish it in a couple of days.
mikey113
Jun 18, 2008 08:49 PM
deej
Aug 25, 2006 06:26 AM
gizzard
Aug 7, 2006 07:01 AM
EMS_0525
Jun 19, 2006 01:22 PM
rkutzner
Mar 15, 2006 10:37 PM
