Going a size bigger with the rear tire
Old Jul 7, 2008 | 03:13 PM
gerrynolan's Avatar
Default RE: Going a size bigger with the rear tire
I ended up getting the Kenda K270 5.1 x 18. This is a great tire. It's bigger than stock but I notice no lack of power. yesterday I hit 90 MPH on the speedo with more power to spare. BTW, I had no wobble to speak of. The stock gearing on the KLX is perfect IMO. I will definiteely be getting the Kenda front tire when I need a new one.
Old Jul 7, 2008 | 04:27 PM
2k1w=no$'s Avatar
I am running a trackmaster 110 rear. If you plan on putting a rim lock on I would recommend that you install 2 of them in each wheel 180 degrees from each other. This will help to balance out the tire.
I am running 2 in each wheel and feel very little vibration at highway speeds.
As far as tubes go. Since the tire is already off I would invest in a heavy duty tube to go in there. If I remember right Kenda tubes use a different one for the 110/120 size than the 100 size.
Old Jul 7, 2008 | 09:52 PM
LearjetMinako's Avatar
ORIGINAL: 2k1w=no$
Tube selection shouldn't be too much of a problem if uses Kenda Tuff-tubes. Kenda makes a wide selection, so that makes it nice to pick a different size for a different size tire.
Old Jul 7, 2008 | 10:19 PM
KDXmike's Avatar
ORIGINAL: 2k1w=no$
Did you drill a hole in the rim for the second rim lock? I have a rim lock and mean to install it when my new tire arrives. I'm gonna try using one rim lock and give these nifty wheel weights a try. They're cheap.
http://www.dual-star.com/index2/Conv...l_weights4.htm
Thanks for the info, I've already spun a tire on the rim and wanted to make sure I use the correct tube. If you're still experiencing a little vibration then you might want to give the wheel weights a go.
Mike
Aug 28, 2012 09:18 PM
steve10
Apr 17, 2008 03:56 PM
fireroad
Jul 13, 2007 09:16 AM
tennisman
Nov 21, 2006 08:40 PM
