front sprocket noise
Old Feb 2, 2015 | 12:09 AM
Duomike's Avatar
Thanks klx678. Glad I've read your post. Today for the first time I measured the chain slack using the standard procedure as per the manual. Only 2 cm instead of the recommended 3,5 - 4,5. Adjusted it to around 4 cm. I guess it was too tight since the first day I bought the bike. The local mechanics here are obviously not too smart.
I ride 99% street so chain doesn't get too dirty. Always use motor oil as chain lube which I apply with a brush. Some of the oil flies off and takes some dirt/dust with it. My feeling is that chains last longer than using regular chain lube. Also the o-rings are keep moist this way.
Will revert re chain noise after some driving today.
Old Feb 2, 2015 | 01:04 PM
Duomike's Avatar
Adjusting for proper chain slack did not reduce the noise. The culprit is apparently the minimalistic front sprocket cover. Need to modify it
neonarc
Feb 13, 2015 12:21 AM
soan
Aug 3, 2011 07:10 PM
hunterhenderson
Jul 22, 2010 01:01 AM
deej
May 8, 2006 08:00 AM
joe sprocket
Jul 20, 2005 11:24 AM
