FMF Q4 install issues
Old Feb 16, 2019 | 02:45 PM
vital04's Avatar
Default FMF Q4 install issues
Edit::: NEVER MIND I WAS BEING A DUMB A
ne
Hey all..
So soooo excited got my Q4 slip on in an started to install it. Looks like the it does not fit exactly as the stock. I am wondering if they sent me the wrong one or if you have to muscle it on a little.
Anyone else have trouble installing an after market slip for an 09?
Looks like the passenger leg protector right behind the foot peg needs to be bent out a little bit. ITs scratching the pipe a bit. and the top screw that you have to use the nut to tighten only goes on a little bit with force. When I screw down the nut it will not be a smooth tighten down. When that goes on, the next hole does not line up and most likely will have to drill it out some what to get it to line up.
Thoughts?
Old Feb 16, 2019 | 05:53 PM
azdeuce's Avatar
Default Fmf
yes Sir..
you always have to do a little tweaking on after market stuff.. the rear guard needs a pull out a bit...
mine was ever so slight touching the air box I left it and just a slight melt not bad.. but everything else lined up... just stick with it and fit things lose might have to make new brackets or add a piece
Old Feb 16, 2019 | 06:55 PM
Ratfink's Avatar
I'll bet you love the sound of it too.
Old Feb 16, 2019 | 07:03 PM
vital04's Avatar
I got it on. There was a spacer bolt stuck to the side of the box I didn't see. Once I got that installed, everything else feel into place. SOUNDS better then I was hoping for. I love it.
akarob
Jul 28, 2011 05:32 PM
TylerSC
Apr 1, 2011 02:01 AM
G19Tony
Feb 4, 2011 10:20 PM
Doc Gatling
Apr 2, 2010 03:35 PM
crf230
May 21, 2009 08:23 PM
