Fit issues with HMF cleared?
Since you have the system, can you tell me, how much clearance is there between the can and the rear fender?
Is there enough to stick your hand between the two, without burning your hand?
Might have to eliminate this exhaust as an option if it means I no longer can use the subframe as a grab handle.
ORIGINAL: sinkoman
https://www.kawasakiforums.com/m_117130/tm.htm
I usually use my rack as the grab handle.
ORIGINAL: dirt_beaver
Searched for some pics on the forum of people with the hmf can. Looks like you might be able to get your hand inbetween the muffler and subframe, but its gonna be tight!
ORIGINAL: sinkoman
I don't like using the rack as a grab handle. I usually remove it before we go offroading, to save some weight. Not to mention, it's alot less comfortable to use, since it's alot higher up than the subframe.
ORIGINAL: sinkoman
Ok, great, i'm not intersted in the BG atm...
ORIGINAL: IG
the BG has clearance as I know exactly what you mean.
layda
IMO the best bang for your buck is a FSW header and a 300 Muffler. It will be under $200.00 for both and will provide as much if not more power than anything else. The only drawback is the 300 muffler is heavier and doesn't sound or look as cool as the aftermarket mufflers. You can always addan aftermarket muffler later.
