The Finale: 2012 KLX250S after mods DYNO CHART and VIDEO
Old Jan 28, 2014 | 08:27 PM
  #31
ahnh666's Avatar
dyno on kustom kraft's website has the klx250 at a 16.58 hp...21.75 hp as a klx330...
http://kustom-kraft.com/files/KLX250...rt_6_22_11.pdf
Old Jan 28, 2014 | 08:57 PM
  #32
wildcard's Avatar
this illustrates that you cant compare different bikes on different dynos directly. however this still shows a 5+ hp increase with a big bore upgrade, which if i recall correctly was dismissed as the single most productive power increasing mod.
Old Jan 28, 2014 | 09:08 PM
  #33
cmott426's Avatar
I like the torque curve with 330 kit. Does anyone have a torque curve for a 351?
Old Jan 28, 2014 | 10:45 PM
  #34
ahnh666's Avatar
this was posted before with just 351cc kit..
With big-bore kit: 24.58 hp and 18.75 ft-lbs
Old Jan 29, 2014 | 01:32 AM
  #35
RaceGass's Avatar
Really? That was just a big bore installation only? No other mods?
Old Jan 29, 2014 | 06:19 AM
  #36
Klxster's Avatar
Ahnh666 's charts are complete and look valid.
SAE correction was used - see "CF: SAE" in the upper right corner.
The correction factors are shown in the lower right corner - on the 351 it was "SAE: 0.98" and the other was "SAE: 0.99" .... So, on that day, the 351's uncorrected HP was multiplied by .98 to get its corrected HP.
Just as important, both charts show the runs as roll-on - "Run Type: RO" ....
Smoothing of 5 is not part of the measurements. It just smooth's the graph.
My charts' atmospheric conditions and correction factor are on the top of page 2 and I did not post page 2. My bad. But the top right corner shows SAE correction was used and it was a roll-on run.
That being said, any chart that does not show this information is suspect, to put it nicely.
Old Jan 29, 2014 | 07:08 AM
  #37
Klxster's Avatar
Dynojet charts are meant to be comparable from one to another as long as the parameters of the run are the same - namely the run type, correction factor and tranny gear used. If the dynos' are calibrated well and the software is using the same SAE revisions, and, in our case, the runs used 4th gear, and they were honest runs without tricks to inflate the numbers, they should be comparable.
The KK chart is hard to dismiss. They sell BB kits and would not inflate the HP of the stock bike. It's from 2011 but I don't know what model year KLX was run. I am surprised to see that much HP (16.58)....
None-the-less, it puts my forum modded KLX at almost a %20 increase in HP and a %27 increase in torque over that charts' stock KLX.
Old Jun 28, 2014 | 12:12 AM
  #38
Richard Avatar's Avatar
I just noticed you mentioning doing the runs in 4th gear. I thought I'd read info before that 5th or 1:1 trans ratio runs produce the highest numbers for any motorcycle. I did a quick search and found a Harley forum that mentions the same thing.
If other KLX dyno runs are in 5th and you are comparing with 4th gear runs you may be automatically a bit behind what others are seeing in 5th?
This YT video of a +32hp 351 with 101 webcams evidently tries both 4th and 5th gears
Old Jun 28, 2014 | 12:15 AM
  #39
Old Jun 28, 2014 | 02:32 AM
  #40
Klxster's Avatar
Found a good article here - Dyno Operators Can "Fix" Results | Super Streetbike
However, it doesn't talk about the effects of tire pressure on the curves.
The articles I'm reading seem to differ on the effects of the tranny gear used. One says a lower gear (e.g. 4th) will produce higher numbers - Another says 1:1 ( 5th) will produce higher numbers... They all agree on the basic premise that the tranny gear used will have an effect on the curves. So a comparison between DynoJet charts using SAE CF, Smoothing 5, etc. etc. will also need to be using the same tranny gear and the same type of test (e.g. Roll on)... If the parameters are the same, DynoJet charts are meant to be comparable....
Klxster
Nov 20, 2014 12:40 AM
batcave
Aug 29, 2013 07:37 PM
Klxster
Jul 31, 2013 02:50 PM
Klxster
Jul 31, 2013 11:10 AM
Lawnica1
Aug 14, 2010 06:37 AM
