Easy Chain Lube (90 Weight users)
Old 11-22-2007, 01:43 PM
gerrynolan's Avatar
Default Easy Chain Lube (90 Weight users)
I have found a great way to lube your chain If you like using 90 weight. I use a small pump style oiler and a foam paint brush. Just pump the 90w right onto the brush and brush it on. Works like a charm and allows you to get at every surface. I like to get the "inside" real well so centrifugal force pushes the oil into the chain.
Old 11-22-2007, 08:04 PM
4SEVEN3's Avatar
Default RE: Easy Chain Lube (90 Weight users)
You dont have issues with dirt sticking to the chain using that 90wt?
Good idea to keep things clean in the process.
Old 11-22-2007, 09:36 PM
gerrynolan's Avatar
Unfortunately, the red clay dust here in NC sticks to everything. I just wipe it down real good with a clean cloth before I lube it. If it's real dirty, I'll blast it with the hose.
Old 11-22-2007, 09:57 PM
klx250s_rider's Avatar
Also found these articles on cleaning and lubricating your chain - give it a spin.
http://www.webbikeworld.com/t2/motorcycle-chain-lube/
or
http://www.webbikeworld.com/t2/motor...chain-lube.htm
Old 11-22-2007, 10:34 PM
jaylaudeman's Avatar
Maybe some advice for some of you cleaning and lubing your chain on the bike is that I use a paint roller tray and a box to put under the rear chainwheel to catch the cleaner or dripped lube.
Old 11-22-2007, 10:42 PM
It only takes a very tiny amount of oil. Just use a tiny drop on each o-ring and and even smaller drop on each roller. Oiling the sides of the chain doesn't do anything but attract dirt - you only need to oil the parts that touch other parts. And oiled sparingly like this you will find no sling.
Old 11-22-2007, 10:54 PM
hokie01's Avatar
I wash my chains with kerosene and a brush and lube with PJ-1 chain lube(the blue one) and have no problems[sm=smiley20.gif]
Old 11-23-2007, 12:02 AM
4SEVEN3's Avatar
That DuPont Teflon spray lube is awesome. Ive used it for a while on non-dirt oriented bikes and have had good results. It completely dries and wont attract dirt.
Hey Gerrynolan...........Im just a little east of you in Guilford Co. When I get some freetime, maybe you can show me some good trails in Mayberry!
Old 11-23-2007, 02:08 AM
gerrynolan's Avatar
ORIGINAL: 4SEVEN3
Cool!!! So far I have found just 1 but it's pretty wild. You are gonna love this Bike man!
Nobrakes
06-11-2007 07:33 PM
deej
03-29-2007 12:28 AM
taystyl
03-07-2007 04:56 AM
bryantjt
05-17-2006 09:56 AM
navyman
04-11-2006 03:10 AM
Quick Reply: Easy Chain Lube (90 Weight users)
