Dynojet Kit for 2007 KLX250
Old Jan 4, 2017 | 01:12 AM
  #181
Klxster's Avatar
Don't worry about the drilled slide - it's done - and you simply have to "work around it" now. And we can do that.. Once I know more, I can make a educated guess for your clip positions.
What main jet are you running?
Old Jan 4, 2017 | 02:53 AM
  #182
donA's Avatar
Default wxhaust
Originally Posted by Klxster
Here is where you start to open a "can of worms".. I own a Q4/Powerbomb system, a PC4/Megabomb system, and a full KLX300R exhaust system.
If you are certain that you will eventually buy a performance header to "augment" a performance slipon, there are things you should know right now.
1. Not all slipons will fit both the stock header and the aftermarket headers (FMF's or the FSW). The performance headers are a larger Dia. than the stock header. Improper mixing of a performance header and slipon is a total waste of time and money - Don't ask how I know(lol). One of my Dyno tests proved this point..
The FMF slipons (Q4 and PC4) correctly fit the stock header and correctly fit the FMF headers (Megabomb and Powerbomb). So, add a FMF header to a Q4 or a PC4 and additional gains in power are "available" - you must change the airbox config and carb setup to take full advantage of the "available" gains.
The FMF header(s) drawback is the lack of, and/or expense of, proper heat shields. Uline carbon fiber shields are about the only "good" shields for the Megabomb. "ARL" found a way to attach the stock shield to the FMF headers though..
2. Only the entire KLX300R system can be used on the KLX250 - you cannot piecemeal the KLX300R system onto the KLX250.. Performance available with the KLX300R system with performance end cap is same-as KLX250 header + slipon.
3. The Four Strokes Works (FSW) header: It will only correctly fit certain slipons - I believe it mates correctly to the FMF slipons..
4. The rule of thumb about slipon mating - If a slipon requires the stock seal in the stock headers' slip joint, it will not mate correctly to any performance header. Such slipons carry the exact same "nipple" size as the stock slipon. DG's, Delkevics, are like this. FMF's and some others will require the removal of the stock seal in the stock header bell - these are the slipons that will fit correctly to a performance header as well.
5. Performance header + matching slipon: Compared to stock header + slipon, this combo "offers" more TRQ higher in the RPM band (6.5k-10.5K) and less in the low/mid range.
6. Stock header + slipon: "Offers" more TRQ below 6.5-7k RPM than #5 and less above.
7. If MCM (Marcelino Cam Mod) is a future mod, it enhances TRQ below 6.5k and offers about the same TRQ above - compared to standard cam timings.
What I have just said saves you hours/days of research in here - but you can verify all with said research..
So, in summary, your choice now needs to be based on what you intend to do in the future. A DG is cheap compared to a FMF. I ran stock header + DGR + MCM + lidless airbox + lidless carb setup - It is a loud, crazy powerful TRQ monster that runs outta breath by 9k RPM. For over a year now, I am running Megabomb + PC4 + MCM + lidless airbox + lidless carb setup. This is power everywhere that pulls to redline. One member running the same has reported top speeds with stock sprockets @ over 100mph (Don't try that at home, he is a professional amateur..)
DGR is loud. DGO is pretty loud. PC4 is my favorite - quiet when driving "normal" , mean "howling" when terrorizing the hoods. Q4 is very quiet everywhere compared to all the others. Most all other slipons are reported to be pretty loud. The Delkevic is loud only once the baffle is removed. The stock KLX300R system with performance endcap is also fairly quiet - comparable to the stock header + Q4.
While adding a "quiet tip" can be done on most all the above, the net effect is to restrict/constrict the exhaust flow which defeats the whole purpose, and the money spent, on improving performance.
My friend, You are an endless wealth of info,! Anyway for now I'll just re jet , new needle , adj thumb screw , uni filter , snorkel removal , save my money For an after market exhaust system ,at that point do the cam mod, Go back in and do what ever is necessary to the carb , I just got this bike I don't even have 20 miles on it and just wanted to open it up a little and make it not so cold blooded .. So thank you for all your help I'm sure everyone here is thankful as well .By the way are you interested in selling your KLX 300 exhaust? What is the PC 4 can you speak of?
Old Jan 4, 2017 | 04:28 AM
  #183
Klxster's Avatar
PC4 = Power Core 4..
Gonna keep the stock KLX300R exhaust system, sorry..
Old Jan 4, 2017 | 05:08 AM
  #184
donA's Avatar
Thanks Bro
Old Jan 4, 2017 | 02:25 PM
  #185
donA's Avatar
Questions keep cropping up.. So the PC4 needs some tweaking to mate to the stock header ? Did I read That right? I've been reading some reviews on the PC4 some people are reporting problems with melting parts etc ,Some people have no problems with install or melting on the KLX , MC Super Store has a sale on the FMF PC4 for $269 I might just pull the trigger , Keep the stock header and be done with it . What are your thoughts about drilling out the starter jet? Thanks This reminds me when I got my kLR 7 years ago ...lot's of questions and research This forum is a lot like KLR.net A wealth of information and very helpful and knowlegeable people willing to help one last thing for now I know there will be more what is the lidless carb set up?
Old Jan 4, 2017 | 03:15 PM
  #186
Klxster's Avatar
I am aware of reports of melting airbox's - apparently it is possible to install a slipon in such a way that it is too close to the airbox. I chose not to do that - you should choose not to do that as well. Also, I do not know if the air injection system played a part in those "melting reports" but removing it from the bike, along with proper jetting, drastically lowers exhaust temps.
The PC4 needs no tweaking, not sure where you got that info..
I did run one weekend with PC4+stock header+MCM+lidless setup - While I did not Dyno test that "mod combo", I am convinced that the increased power levels were more "evenly distributed" from idle to about 9.5K RPM compared to the smaller Dia. midpipe on the DG slipon.. It is a little louder than when used with the MegaBomb header - The Megabomb/Powerbomb headers have a quieting effect..
Since you've asked about my thots on drilling the starter jet, I assume you've read enough of my posts to know how I feel about peeps molesting their KLX's with drill bits. There is no need to drill anything, anytime, ever. Even the 2206 kit has been found to work better if you do not drill the carb slide as per the instructions. However, the starter jet drilling is a benign "drilling" - it only affects the amount of fueling during "full choke" operations, nothing else.. Also, the members that tout this mod are members I trust (IDRIDR, TNC, etc).. The only other "drilling" that I find almost acceptable is the opening up of the crankcase vent port on the airbox.
Your best lidless carb setup will depend on your average riding altitude. It will use the needle from the DJ2206 kit or the DJ2152 kit, a properly sized main jet, etc etc..When you get to that point, I can provide you the exact recipe for your lidless power enjoyment.
Old Jan 4, 2017 | 05:00 PM
  #187
donA's Avatar
Thanks , I was confused reading rule #4 on one of your last posts regarding the slip on and the stock header pipe joint.. Anyway I'm goina order the pipe and re jet like we already discussed .. When the can comes I'l throw it on and live with that for a while before any more tweeks Thanks again
Old Jan 4, 2017 | 05:03 PM
  #188
Klxster's Avatar
I've posted a new thread about all this exhaust stuff. It is easier to understand as I expand on many aspects and will continually update the top post with the latest information..https://www.kawasakiforums.com/forum...rations-44444/
Old Jan 4, 2017 | 05:23 PM
  #189
^ performance exhaust thread linked in the FAQs. Good stuff there Klxster.
Old Jan 4, 2017 | 05:46 PM
  #190
Klxster's Avatar
You da man IDRIDR..
