Dynojet Kit for 2007 KLX250
Old Jun 21, 2016 | 07:34 PM
  #121
Klxster's Avatar
Ok, reset to 3.5 out, adjust idle to 1500-1600.. If you still have popping you can't live with , the cure is a #40 pilot jet..
Old Jun 21, 2016 | 07:35 PM
  #122
Klxster's Avatar
If you have a leaky butterfly shaft seal, none of the above will fix the pops..
I should say, check the butterfly shaft seal on your next "fire up"...
Old Jun 21, 2016 | 07:37 PM
  #123
kshanks5's Avatar
I just edited by last response. I forgot that I didn't have any high heat silicon when I installed my slip on, but I wanted to try it out. Meant to add the silicon later. I assume this may cause some popping. Could it affect 5,000 rpm?
Old Jun 21, 2016 | 07:45 PM
  #124
Klxster's Avatar
Yes, No..
Old Jun 21, 2016 | 07:54 PM
  #125
kshanks5's Avatar
Thx....do I still do 3.5 turns?
Old Jun 21, 2016 | 07:57 PM
  #126
Klxster's Avatar
Yep. That's where it needs to be - near sea level..
Old Jun 21, 2016 | 07:59 PM
  #127
kshanks5's Avatar
Thx for all your help. Sometimes I feel like I've got a handle on the carb stuff, then I don't
Old Jun 21, 2016 | 08:07 PM
  #128
Klxster's Avatar
You're welcome.. We need to start finding and listing the solutions for this bogging/stuttering issue that comes up from time to time.. So far, about all I know of is Neonarc's butterfly shaft seal thread - https://www.kawasakiforums.com/forum...replace-43126/ - but this is not the issue with some other members stuttering problem..
Old Jun 21, 2016 | 08:58 PM
  #129
Klxster's Avatar
Originally Posted by kshanks5
I'm going in to check everything again. Question on the brass ring. It has a ridge at about 3/5th. Should the longer side of the ring be up or down?
Longer side goes up. It protrudes into the carb barrel..IIRC..
For the readers, he is talking about the Needle Jet. It sits on top of the emulsion tube. It is the brass item that the needle slides up and down in. It protrudes into the carb bore and is visible - the needle resides in it at all times during operation. It's orifice diameter is an important component to the fueling curve you get with a given carb setup.
Old Jul 4, 2016 | 02:55 PM
  #130
kshanks5's Avatar
Ok, took the carb off and checked everything, turned air out to 3.5, put everything together and noticed a DJ washer on the floor when I was cleaning up. Took all apart again and reinstalled the washer.
Decel almost completely gone. The bogging between 5-5500 rpm almost gone, just a slight hesitation when I'm around this rpm range and I crack the throttle. No where near as bad as before. Unless you have a suggestion I'll probably live with it
How did you know that 3.5 turns would fix this, when you've always recommended 2.5 turns with my set up?
