DynoJet kit for 09 250s
Old Apr 15, 2019 | 06:43 PM
vital04's Avatar
Default DynoJet kit for 09 250s
Hello all..
I am at the point of updating the carb for my 09 250s I was doing some research and based on my mods I will need a stage 2 kit. Does anyone have a link to the kit on amazon or somewhere else? I just want to make sure I get the right one.. I thought it was part 2206 but, I have been wrong a few times lol.
Thanks for reading.
Mods: exhaust Q4, 13tooth. thats about it for now.
Old Apr 15, 2019 | 08:06 PM
reinigef's Avatar
I believe you want kit 2152. As I recall 2206 was for the KLX 300. You may want to check KLXsters tag line for jetting options.
Amazon Amazon
Old Apr 16, 2019 | 01:22 AM
Abramsgunner's Avatar
I'll second the 2152... and don't drill the slide (don't think 2152 directions call for it anyway). Also may want a larger pilot jet that is not part of the kit (38 or even 40 depending on your altitude.)
Old Apr 16, 2019 | 02:51 AM
Klxster's Avatar
Hey, Vital04..
If you are going to leave the lid on the airbox (regardless of which snorkel or if you intend to run snorkel-less) , you should probably just get the 2152 kit and install as per instructions for stage II.
You can also use the 2206 kit BUT do not drill your slide with the included drill bit.
In either case, a #40 pilot jet will make you much happier with starting and low rpm throttle response.
Old Apr 16, 2019 | 12:50 PM
vital04's Avatar
Thanks all..
Just to be sure I am going to grab this dynojet kit stage 1 and 2
Amazon Amazon
@Klxster and the #40 pilot (looks they only come in a kit of 5 or a much larger kit. not sure if it matters)BTW I read your entire thread of carb setup and first WOW GREAT job and my eyes might be permanently crossed now):
40pilotJet 40pilotJet
the snorkel is indeed off. I was thinking of making a slider mod for the side of the air to open and close depending type of trails I am in. This past weekend I went through about 3 ft of water/mud. powered right through it. the quad I was with got stock . It was so much fun. So much mud!!!! I had a blast. I am going to start bringing my go pro to post up some pics and vids.
Old Apr 16, 2019 | 01:56 PM
vital04's Avatar
Hopefully this will fix some of the starting issues I have been having. Seems like the bike floods so easy. I bucked it on a small incline and could not restart it with out jumping it down the inline in 2nd.
Old Apr 16, 2019 | 05:40 PM
Klxster's Avatar
VItal04, for the #40 pilot jet, you go down to a Kawa dealership and order this - #40 Pilot Jet: part no 92064-1108
Old Apr 16, 2019 | 07:15 PM
vital04's Avatar
Thank you !
CraigT
Feb 11, 2017 04:37 AM
GaryC
Sep 17, 2009 03:48 AM
JasonFMX
Feb 17, 2009 03:37 AM
rcraig
Dec 11, 2008 12:09 AM
Davebert
Apr 1, 2008 01:42 PM
