Checking the Oil
Old Apr 7, 2019 | 01:47 PM
Haldor's Avatar
Default Checking the Oil
Hi all,
Just curious how you guys are checking your oil level. My 2018 rear brake foot control completely covers the oil level sight glass requiring me to use 3 hands to check the oil level. There has to be some trick I just haven't figured out. Advice anyone?
Old Apr 7, 2019 | 08:19 PM
Abramsgunner's Avatar
Originally Posted by Haldor
Hi all,
In general.. I use 3 hands..
FYI, the sight glass being covered up by the foot brake does not protect it from getting cracked when riding in gravel... Doh!!!
Old Apr 7, 2019 | 09:14 PM
Get a stick, screwdriver, paint stirrer, etc. and jam it above your brake pedal and under the engine case...or wherever works...to push the brake pedal down as far as it will go. Then you should get a suitable view of your sight glass. For me it sounds like your brake pedal is adjusted kind of high. However, a lot of this can be preferential, so it is what it is if it works for you. Make sure you have enough free play. I find I like my pedal a little low and with a decent amount of play during any serious off road riding, because your boot starts moving around quite a bit and causes you to ride the brake unnecessarily otherwise...at least for me.
Old Apr 7, 2019 | 09:51 PM
Haldor's Avatar
Brand new bike. Haven't adjusted anything yet.
Old Apr 9, 2019 | 09:18 PM
GBAUTO's Avatar
I park the bike on level ground. Step over to the RH side of the bike, kneel down and with one hand grab the handlebar and start to lean the bike towards you. When it feels like it's level, push down on the foot brake with your free hand and look at the sight glass...more than one way to skin a cat.
Old Apr 11, 2019 | 05:54 PM
wetfootnelly's Avatar
i thought this is how everyone does it! sheesh, not that hard..
Old Apr 11, 2019 | 07:04 PM
Yeah, that's exactly how I do it as well... and I've never dropped the bike on my head. Well, there was that one time, but I was tired.
Old Apr 12, 2019 | 01:53 AM
klxnoobie's Avatar
Well that explains a lot
Old Apr 12, 2019 | 05:07 AM
Haldor's Avatar
I am huge (6'4"), 60+ and my knees are shot. Try doing that while kneeling on sharp rocks. That is what kneeling on any hard surface feels like to me.
So I guess the answer is no, there really is no other way to do it.
I will probably end up reshaping the foot lever so it doesn't obstruct the sight glass. My plan is to carry a small inspection mirror so I can check the oil while standing. I take things like checking the oil regularly seriously.
Old Apr 12, 2019 | 03:03 PM
