Checking the Oil
Old Apr 13, 2019 | 04:42 PM
durielk's Avatar
My bike has never used ANY oil! Period. I check it every once in a great while. Now if you see oil all over your rear end or tire, you should check it and slow down on the corners.
Old Apr 13, 2019 | 05:04 PM
Haldor's Avatar
I am hoping the KLX is not an oil burner. This is one of the negatives to the KLR650. And if you run low on oil, you risk burning up one of the exhaust cam journals which requires replacing the head. I had to replace the head on my 2007 due to this and that experience turned me into a check your oil ****.
Old Apr 14, 2019 | 01:39 AM
drm's Avatar
drm
Is the 2018 different than the 2007?
Old Apr 14, 2019 | 04:53 AM
Haldor's Avatar
I am going to try adjusting my brake lever. If that was how mine looked, I would be happy.
What is weird is that the sight glass would be easily visible if the lever didn't have that unnecessary hump in it.
Old Apr 14, 2019 | 05:56 AM
Haldor's Avatar
This what mine looks like.
Old Apr 14, 2019 | 11:08 AM
I am huge (6'4"), 60+ and my knees are shot. Try doing that while kneeling on sharp rocks. That is what kneeling on any hard surface feels like to me.
So I guess the answer is no, there really is no other way to do it.
I will probably end up reshaping the foot lever so it doesn't obstruct the sight glass. My plan is to carry a small inspection mirror so I can check the oil while standing. I take things like checking the oil regularly seriously.
Ride with a friend and say "Would you look and check my oil while I hold the bike up?"
At home, get one of these two:
Old Apr 14, 2019 | 02:30 PM
drm's Avatar
drm
looks like the hump allows it to clear the foot peg bracket
id only adjust it if its comfy for you (ergonomics wise). good luck!
Old Apr 15, 2019 | 02:40 AM
durielk's Avatar
#1. He is low on oil!!!! ...and he has his brake adj way too low for me!
#2. Push down on the brake!!!! ....and where's the dirt?
Old Apr 15, 2019 | 01:25 PM
drm's Avatar
drm
well duh, the bike shows low level when on the kickstand...
You guys wear tennis shoes? how do you ride like that in proper offroad boots?
Old Apr 15, 2019 | 01:31 PM
RageHardIntoTheBendies's Avatar
Longer legged people sometimes sit further back on the seat which will require the lever to be adjusted further up.
I got stumpy legs and also always have boots on so mine is adjusted further down like above.
