Drain Plugg Broke HELP!!!
Old May 20, 2007 | 01:20 AM
doitinthewoods's Avatar
Default Drain Plugg Broke HELP!!!
oil drain plugg head came of the bolt How will I get it out???
Old May 20, 2007 | 01:23 AM
Bluebeast's Avatar
Default RE: Drain Plugg Broke HELP!!!
you could try and easy out. then just get a new bolt to replace it with that way you don't get any metle shavings in you oil pan.
Old May 20, 2007 | 02:55 AM
lcpl0331's Avatar
all the way off? meaning nothing to grab at all?
Old May 20, 2007 | 04:17 AM
KLXer's Avatar
Try a left hand drill bit, it may spin it out. The good thing isif the head is gone it should thread out very easy.
Old May 20, 2007 | 04:46 AM
Kawi Wawi's Avatar
wow, it must have been way too tight... it should only be 15Nm which is not very tight at all.
I know - doesn't help you now, but for future reference - they shouldn't be tight at all.
Old May 21, 2007 | 04:19 AM
mooredan's Avatar
Use an EZOut. My advice is to use one that you think might be too small. Otherwise the drill bit that you have to use gets too big and you end up drilling out the bolt so that the sidewalls are too thin. (I've done that before and what was a relatively easy problem to solve became a much more difficult one).
Another word of caution, you definitely do notwant to break the EZOut off in the drill out bolt.
Old May 21, 2007 | 08:32 AM
TeamKLX250's Avatar
and don't forget you will have the oil to deal with once you get the bolt out [8D]
Old May 22, 2007 | 01:31 AM
Got the bolt out using a left handed drill bit thanks for the advice
Old May 22, 2007 | 03:14 AM
lcpl0331's Avatar
good job!!!! that could have turned into your worst nightmare. i've been watching to see how you made out with that. glad it turned out fine for you.
CousinLarry
Dec 22, 2010 02:33 AM
fewdecentwords
Jun 1, 2007 06:26 AM
DJFields
Dec 16, 2006 02:45 AM
markturbo
Dec 12, 2006 03:26 PM
Notstock
Mar 8, 2006 03:26 PM
