drain coolant 86 600r
Old May 31, 2007 | 09:15 PM
fewdecentwords's Avatar
Default drain coolant 86 600r
where can i drain all the coolant out of? i dont see a plug in the radiator. i was thinking of mabye taking off the lower hose but i dont really want to.
Old May 31, 2007 | 10:07 PM
Notstock's Avatar
Default RE: drain coolant 86 600r
take off the loest hose connection on the motor and most of the fluid should drain out.
Sux not haveing an easier way, but just put a pan under her.
Old May 31, 2007 | 10:15 PM
shinobi636's Avatar
^^^What he said^^^
Old May 31, 2007 | 10:31 PM
k ill do that. thanks i was hoping for another way lol.
Old May 31, 2007 | 11:02 PM
Bluebeast's Avatar
As far as i know that's the only way.
Old May 31, 2007 | 11:39 PM
Notstock's Avatar
ORIGINAL: Bluebeast
Yep. My way or the highway bioatch
Old Jun 1, 2007 | 06:26 AM
speedracer138's Avatar
Look on the LH side behind the alternator cover, you will see the water pump. There is an 8mm drain bolt in the middle where you can drain the coolant from.
407guy
Oct 10, 2023 01:42 AM
mark1980ep
Ninja 500R
Mar 26, 2011 02:07 PM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
asenft
Jul 4, 2005 09:43 PM
