drain coolant 86 600r
where can i drain all the coolant out of? i dont see a plug in the radiator. i was thinking of mabye taking off the lower hose but i dont really want to.
RE: drain coolant 86 600r
take off the loest hose connection on the motor and most of the fluid should drain out.
Sux not haveing an easier way, but just put a pan under her. |
^^^What he said^^^
k ill do that. thanks i was hoping for another way lol.
As far as i know that's the only way.
ORIGINAL: Bluebeast As far as i know that's the only way. |
Look on the LH side behind the alternator cover, you will see the water pump. There is an 8mm drain bolt in the middle where you can drain the coolant from.
