Diving into cam chain issue...
Old Sep 1, 2010 | 03:16 AM
Originally Posted by RimBender
On my klr the noise was the decompression device, it had got loose enough it was tossing it's spring. After a few times I removed it completely and have never looked back.
Did you notice much more difficulty in turning the engine over? I saw a few posts elsewhere about removing the KACR, (on KLR's) a few made it sound like there was quite a bit of added strain on the starting system. Obviously it makes it harder to turn the engine over without the compression release, but was it noticeable or seem excessive?
Thanks
Dan
Old Sep 1, 2010 | 03:40 AM
therivermonster's Avatar
Originally Posted by therivermonster
Higgs, interesting to read about your work on the tensioner.
I took the 12mm bolt out today and tried to push on the tensioner with a fair amount of force, but it wouldn't budge. I then removed the assembly completely to inspect the tensioner plunger and all looked good, maybe 1/3 extended. So I reset the unit and reinstalled.
I'm pretty sure that the sound is still there, but I guess that it is something that I will have to live with until I open up the top end for valve clearance inspection. When I'm in there I'll look further into the cause of the noise.
Any other ideas?
It doesn't sound like anyone else who has manually adjusted their "auto adjuster" has had trouble getting a click out of it. I wonder if when I had last shut the engine down before I tried the adjustment, maybe it was in a position where the cam chain was under tension thus making it difficult to push in the tensioner plunger to get a click?
Maybe I'll try the 8mm bolt method and use the mechanical pressure of the bolts to tighten up that crazy chain.
Old Sep 1, 2010 | 04:47 AM
09'Kawi250s's Avatar
Originally Posted by deej
Mine still makes noise at 14,400 miles.
still got the original in there deej? cuz im at 12,000miles and its pretty loud dont know whether or not to ignore it or replace it?
Old Sep 1, 2010 | 05:10 AM
To achieve the slackest point in the chain on the tensioner side, just turn the motor over on the flywheel nut at the crank...counter clockwise of course. This pulls the cam chain tight at the front of the engine, leaving the most possible slack on the tensioner side. You can do this several times to insure you've gotten the most slack out of the chain. This is also a way to adjust many manual tensioners...engine off and finger-tightening the adjuster plunger bolt after a couple of hand-turned revolutions on the crankshaft/flywheel bolt.
I don't think I'd recommend the loosening of the tensioner body bolts and then retightening method for most folks. You'd better know what you're doing with that method. You could easily get the tensioner too tight. Pushing an allen wrench or other item down the tensioner bore with the cap off is a safer and probably just as effective method.
Old Sep 1, 2010 | 09:36 PM
It seems like a good aftermarket manual tensioner is needed for the KLX 250s given all of the chain noise issues.
TNC- It's great to hear that you and Mark are working on a tensioner. Are there other manual tensioners available?
I am going to do an oil change tomorrow, so I think that I'll pull the tensioner to give it a look over and reset it. I can just reset the tensioner and reinstall, right? By reset, I mean push the plunger all the way in, or is there a better technique?
All the information is great! Maybe given the popularity of this topic, the mods might make a sticky with links to the many threads on engine noise, cam chain noise, cam chain guids, etc. Just a thought.
***I know that there is a downloadable service manual for the 09 KLX 250s on the forum, but what is the best manual for an 06 KLX 250s?
I've not seen another one yet. I've been waiting for a bit more feedback from TNC. I also have to send him a different head style adjusting nut to try out.
I want to get this going in the next few weeks. It's worked great for a variety of other models. I just don't have a KLX250 to work with personally.
Old Sep 1, 2010 | 10:00 PM
klx678 is Mark Kreiger, for those who might not know. My nearly 3 week Colorado trip and a big AC install at home just before that slowed down my opportunity to pursue this like I normally would. The proximity of the header pipe to the adjuster nut on the first model made any adjustment with the engine running a hot and touchy...pun intended...effort. I couldn't turn the adjuster incrementally in a manner to closely listen to the cam chain to get a proper feel for the adjustment IMO. The allen head version he's sending me now should alleviate that. The "sound" method while the engine is running is probably the best. I'm beginning to think that the second spring setup on the KLX that's just below the actual adjustable tensioner may somehow interfere with my efforts to do the engine-off, fingertight method that usually works just fine. Hopefully the new allen head adjuster on the plunger bolt will address this.
Old Sep 1, 2010 | 10:26 PM
You could do that, but that is putting excess tension on the cam drive. Parts can and will wear faster. There is a reason for the problem that I've observed and reasoned out a bit more. Here is a sort of definition of my observations and thoughts I formed while dealing with my KLX650 tensioner, a similar ratchet style tensioner.
Now to address what I observed before making my first manual tensioner. The rack and pawl design with a spring will constantly put some minimal pressure on the chain slider which would promote wear. The spring isn’t strong enough to resist kickback in the chain under crank deceleration, so it isn’t of any value in tension control in that area. What it does is put enough pressure on the rack to push it forward and the pawl clicks in as the chain seats in and cam drive wear occurs… but not always completely.
The thing I've found interesting in both the KLX and some other forums is the expectation that Kawasaki engineers are infallable and that replacing these tensioner parts and resetting supposedly automatic tensioners would be a normal practice. If it is automatic shouldn't it be automatic? Why should I "reset" or back out until I hear a click, effectively doing a manual tensioning and also making it too tight? I don't buy it. One guy on the KLX site thinks it's okay
to replace HyVo chains at 12,000 miles. Those chains are the same design used in some automobiles that run for about a lifetime and on the primary drives of many in-line fours. Other guys think it's okay to back out the mount bolts to effectively override the automatic system.
Now to address what I observed before making my first manual tensioner. The rack and pawl design with a spring will constantly put some minimal pressure on the chain slider which would promote wear. The spring isn't strong enough to resist kickback in the chain under crank deceleration, so it isn't of any value in tension control in that area. What it does is put enough pressure on the rack to push it forward and the pawl clicks in as the chain seats in and cam drive wear occurs… but not always completely.
The key point is that the automatic tensioner clicks in incremental amounts. Cam chains wear/seat dynamically (no increments). When the wear, which by my manual tensioner adjustments has proven to be minimal, isn't enough to move the rack forward forward enough to seat in, but just barely over the tip of the tooth there will be problems. And of course there is no way to tell this. Under cam drive deceleration the rack can kick back hard enough to force the rack back over the pawl, damaging the edges of both by chipping off the edge. This is the same effect as the rounding of shifter dogs when gear boxes are abused with incomplete or missed shifts, but on a much much smaller scale. It takes a magnifier to see the wear (actual rounding), but not the evidence of the wear (polishing of teeth). If this occurs over and over the edges round, much like shifter dogs can, but eventually the rack may start skipping over multiple teeth.
After two of the OEM tensioners in 15,000 miles, the second one costing $70 initially and then about $300 in rebuild costs after it failed, I have no qualms about recommending a manual unit. With simple adjustments on fairly wide intervals after seating in of any new components, the unit is reliable as a rock. I've got 28,000 on my bike with a manual unit, I can't remember now when the last adjustment was made, but it still isn't making any rattling noise except when cold and that is due to play allowed for thermal expansion. I have another rider with a Concours who has 23,000 on his with the same minimal adjustment. Less than one full turn of the adjuster bolt. It is so small a movement if you look at the OEM rack you'll understand why it is possible to have one go bad and another one go without issue. It's just not worth the $70 for the automatic one if it fails again. The manual units are more reliable, the biggest problem with them is when a rider doesn't recognize when it rattles it is time to adjust it.
Now if you adjust the manual tensioner the way I describe it, or another way I learned from the Eliminator owners, you will have taken virtually all the play out of the cam chain drive, but put virtually no tension on it. The OEM automatic tensioner's spring actually does put unneeded tension on the drive all the time, pushing in. All that need be done is take out all the slack, that is
ideal.
The play is taken out by either listening for the rattle caused by the loose chain play, which can also be felt if actually doing the turning in by hand. I will tell you I put a socket on my inch/pound torque wrench, held it and twisted as hard as I could... I couldn't even get the beam to deflect. So obviously hand tightening is nearly impossible to overtighten, but I still go by the sound and feel.
Since this is all done at full operating temperature everything is thermally expanded to probably a thousandth or two of maximum growth over all, all inclusive. In other words the drive is as tight as it will get due to expansion. This will result in a very tiny amount of slack when the engine is cold, but that slack is so little it will be inconsequencial as my 28,000 miles show it to be.
As for the chain, again those chains are the same design used in some automobiles that run for about a lifetime and on the primary drives of many in-line fours. They are known for durability when bathed in oil - which they are. Do the research on the internet, I did. I also have never seen a cam chain actually break in the 22 years I spent in a mid-size dealership where I used to love to go hang out in the shop. The one thing I have seen is damage caused by loose cam chains beating up the sliders, variable cam timing as the chain slack allows it to vary by a large amount when the tensioner allows .250 movement when the rack pushes back and forth over 3-4 teeth, and overly worn cam chains from that slapping and snapping around. I will say I did see some Honda ATC200 engines, which use a roller chain, that didn't have the manual adjustment done on them at all, resulting in a lot of chain slap... enough to break the tensioner sliders in them and actually cut through the cylinder cam drive tower area on one. Incredible!
Now the negative on the manual unit. You have to be aware of any ticking coming from the left side cam drive area when it's hot, so you can k ow when to adjust it. That's an actual audible signal that is far quieter than the clatter from a failed OEM automatic tensioner, indicating far less play. It's usually a small adjustment of 1/8-1/4 turn of the adjuster bolt (one full turn is .060" on the M8-1.25 bolt I use) and might only come about every several thousand miles.
You'll actually check your valves more often than it will need adjustment. All you do is every so often at the end of your ride let the bike sit there and run while you take off your helmet and listen on the left side to see if it's ticking at all. Just don't confuse valve tick from the head with chain ticking from the tensioner area. I even got a mechanic's stethoscope to do mine just to be sure. It was more for the Zephyr where the drive is in the center of the engine, the outside cam drives are easy to hear.
I hope this is of some help in understanding the whole process. It is what I've learned both from the rebuild time when we, the mechanics who built the top end (I was selling bikes well enough part time I knew I'd get the work done faster by them than doing it myself and could afford it) and I, decided a manual tensioner system was the best route and all the work, reading, and thought process in the past ten years since. It is not a guesstimate in the mechanical aspect, but it is not a statistically proven situation since I only have had two engines at my access. There is the back up from a few hundred other riders who have either made or bought manual tensioners for their bikes; KLX/KZ/GPz/ZR/ZX/ZL/ZG and DRz. Not all automatic tensioners fail. If the indexing falls in place properly for the mechanical requirements they will work. If it doesn't they will fail..
I really don’t know why the earlier goofy spring and thread design on the Zephyr 550s fail, I could care less, I just know the ones on the Zephyr 550s regularly crap out. Someone had actually screwed with and messed up the one on my bike apparently trying to make it work consistently.
I also bought into the “Kawasaki engines are noisy” with the KLX and ended up several hundred in the hole due to two tensioners going bad. I got the same comment on the Zephyr, but knew different. That bike has about 7000 on the tensioner without any noise so far. I used the mechanic’s stethoscope on it to listen to the cam drive and heard basically nothing so there is no rattle of a loose chain and no “shushing” of overly tight tension on the slider. With the drive on the outside like the Concours and my KLX it’s much easier to listen for noise without aid.
I had my first Concours owner, who lives near me and has some of the same friends, bought one after bantering back and forth with a dealer. The dealer said nothing could be done and that his bike was “old technology”. He called me the day after he picked up the tensioner to tell me how it worked and that I needed to shorten the bolt a bit, which I did, but I still make sure it’s long enough. That was last fall. No problems, otherwise I’d hear from him.
You can bounce it back and forth all you really want, but when a tensioner does quit working you have to make a choice. Do you do stop-gap resets that may or may not work? Maybe do that a few times, but not if it happens over and over. Do you buy a new tensioner and sliders? Well if you have to buy new sliders you have tensioner issues and buying a new tensioner can run a fair price. Do you go with a manual tensioner that you or a good mechanic can understand and deal with, keeping tension at a minimum and not having to replace sliders as often since the chains never get overly loose? Many of us went that way. I am telling you it is a fix if done soon enough, within a thousand or so miles. If it doesn’t deal with the noise look elsewhere, because it’s no longer the cam chains. I spent part of an evening on the phone actually while an Eliminator owner was doing the adjustments. We found his noise wasn’t totally the cam chain adjustment. Apparently the pollution control air injection had some gaskets not seated right and making noise. He now rides a quiet, except for exhaust maybe, Eliminator. He knows the cam drive is tensioned decently without excess play.
Your call. But remember – “if it ain’t broke don’t fix it.” No cam drive noise = no tensioner problem, why bother changing it. If it ever goes, fix it then.
One thing I want you to understand, after the tensioner is adjusted at full operating temperature, the engine may tick a bit when started up cold. The reason for the ticking is thermal contraction/expansion of all the engine parts. When chain tension is set properly at full operating temperatures there is little if any actual tension on the chain so as not to cause premature wear on parts, so when the engine is cold everything has contracted in size and there is a bit of play in the chain for the first few minutes of warm up. It should be of no concern, because the engines warm up quickly and the play is so small. It is no where near as bad as the play when an adjuster fails and not all the time as with a failed tensioner. I want you to understand why, when the engine is cold, there is a small amount of cam chain noise. Presently my own KLX650 has done 28,000 miles with this manual set up, the Zephyr is approaching 10,000 miles without any problems.
As you see, I've put a fair amount of thought and work into this area. It was actually more by mistake than by intent. I was willing to buy a tensioner for the Zephyr, but couldn't find one or get one made. My requests were ignored. So with some inspiration and some manufacturing knowledge I made one - plus anohter five. The Yahoo KLX650 group has been extremely supportive due to my being a member and also due to price. That model has a high rate of failure. From there, people just found out about me and my willingness to try to help. I want to do the 250 tensioner, but I want to have full confidence as I do in the others I make. I am very close to that point. I think we have most everything taken care of.
Old Sep 1, 2010 | 10:30 PM
  #28
TNC, didn't realize you were here. I'll send out the allen nut tomorrow.
Old Sep 1, 2010 | 11:08 PM
  #29
higgs's Avatar
Nice Info KLX 678
Old Sep 2, 2010 | 01:14 AM
  #30
RimBender's Avatar
No problem ever, but i do keep my bike plugged in so the battery is fresh.
One of my other bikes is 13.5 compression and big bored so cranking gets hard when it's hot. Solution: When a motor is shut off the piston ends up right before TDC compression so doesn't get a running start. So if I hit the button and it doesn't move I just roll backward in gear to get the piston back down where it can get a running start, works good every time.
If the 650 sans the decomp ever gave me trouble I'd do the same. never needed to.
Thanks
Dan
