Did the MCM today
Old Jan 4, 2015 | 08:48 AM
Richard Avatar's Avatar
I took it out for a quick retest ride (after replacing the front tube..) and it seemed okay now.
Old Jan 4, 2015 | 01:52 PM
4vman1's Avatar
Now I know that this is way above my pay grade, but it has been mentioned quite a bit that the cam mod adds a bit of torque down low and signs off earlier, exactly what you don't want to bring to a dyno at wfo. Shouldn't you have at least left it in long enough to test ride it or are you primarily riding at the upper half of the tach?
Old Jan 4, 2015 | 02:30 PM
Klxster's Avatar
Are you saying you've been riding on a flat tire ?
Old Jan 4, 2015 | 03:11 PM
Not sure if your "above my pay grade" is in reference to doing the mod, but if a rider can do the valve shimming the MCM isn't that hard with clear instructions. It is pretty straight forward, but requires meticulous attention to detail - aka being positive that the cams are positioned properly with the timing marks toward the center being 2-1/2 teeth above the surface of the head (counterclockwise for the intake cam and clockwise for the exhaust cam).
WFO on a dyno is measuring power, not about running big rpm, so it is well worth running any mod if the money is there to do so. Big inch V twins that will only rev around 6500-7500 are put on dynos, some twins are pushing triple digits at those rpm.
One last comment, based on Marcelino's dyno runs the power peaks within around 200 rpm of the stock peak, so it isn't signing off much earlier and the difference not being that noticeable, plus torque is up across the range, not just down low. The noticeable difference on top, as I think KLXter has pointed out before in other posts, is that the rise in power has emphasized the drop on the over run. That drop exists regardless.
Old Jan 4, 2015 | 03:31 PM
4vman1's Avatar
The "above my pay grade" comment was basically saying that I have not done the mod myself and so I don't really know what I'm talking about in the subject other than the few posts that I've read on here. I have installed a #190 cam in my DR650, but haven't cracked open my KLX. I guess I should have left the first sentence out and only asked if Richard should have left the mod in for a test ride before giving up on it.
Old Jan 4, 2015 | 04:16 PM
Originally Posted by Klxster
.. Perhaps the MCM, in fact, doesn't work on older KLX's
Was this suggested by others previously? Just curious.
Old Jan 4, 2015 | 04:59 PM
Klxster's Avatar
My research on the MCM thread found only one entry suggesting the MCM only works on '09 and up ( IIRC) .. That entry was from Jeff Ward - lets go find it..
Old Jan 4, 2015 | 05:08 PM
Klxster's Avatar
Search the MCM for jeffward posts... His english is difficult to decipher but here is the page on the MCM for you to "start crunching data" on..
https://www.kawasakiforums.com/forum...34/#post469775
Old Jan 4, 2015 | 05:31 PM
Klxster's Avatar
I decided that jeffward's posts were too ambiguous to place merit on .. regarding MCM results on older than '09 KLX's..
If this thread is a joke, Richard, it's time to come clean.. MCM results are like it's only getting half throttle ??? Cmon..
Old Jan 4, 2015 | 05:35 PM
ol'klx-er's Avatar
Was his test run of the MCM done with a low front tire? Are some of his other runs also affected by inconsistent tire pressure?
