D606 Question.
Old Apr 4, 2007 | 03:30 AM
Ginsu4u's Avatar
Default D606 Question.
What size 606's are you guys running. I need a new one and am thinking of going with the 130 instead of the 120 I have now. Will the 130 even fit? Looks like it will. Opinions?
Old Apr 4, 2007 | 03:35 AM
kawiridr04's Avatar
Default RE: D606 Question.
i remember hearing that the 130 is the biggest u can get. so it should fit
Old Apr 4, 2007 | 05:08 AM
DirtSurfer's Avatar
Not sure, I am currently running with a 120/90 - 18 on the other bike(my sons bike now). I remember someone saying that the 130 might be too big for our swing arm.. If not, it will be GREAT traction I'm thinking!!
I actually opted for the Kendar Trakmaster 2 in the larger 120/100 - 18 size. Nobrakes has an older one on the bike I bought from him, and it looks MONSTROUS, but a bit worn, so I'm thinking the new one will be quite a claw!!
Old Apr 4, 2007 | 05:09 AM
All I know about the 130 is that a friend of mine put one on a 2004 KLR 250 and it rubbed on the stock muffler when the suspension moved. Now I realize that they are different bikes, different years, but it might be wise to stay with the 120. Also keep in mind, the bigger/wider tire is going to take a little more power to get it to spin in different riding conditions.
Old Apr 4, 2007 | 05:22 AM
cwgoff's Avatar
I am currently running the 130 width Cheng Shin C858 and there is plenty of room on each side. Obviously tread pattern will make some different. There are definitely differences in widths between manufacturers and tread designs even if both are a reported 130, but there is enough extra room that I would bet that anybody's 130 would fit without any problem.
Old Apr 4, 2007 | 05:33 AM
Kawi Wawi's Avatar
Go with the 130... I just changed out my stock D603's for D606's at both ends.
Here's what I changed from and to:
D603 3.00 x 21 front D606 90/90 - 21 front
D603 4.60 x 18 rear D606 120/90 - 18 rear
I measured the old and new tires with calipers, and the 606 rear is at least half an inch skinnier than my old (stock) tire.
Definitely go with the 130. Had I known this, I would have gotten 130/90-18.
HeavyFuel
Jul 9, 2011 02:12 AM
steve10
Apr 17, 2008 03:56 PM
klx250s_rider
Jul 11, 2007 09:05 PM
Kawi Wawi
Mar 31, 2007 01:09 AM
rkutzner
Feb 25, 2007 01:36 PM
