CYCRA HANDGUARDS W/TRIPLE CLAMP MOUNT
Check out these sweet cycra probend hand guards with triple clamp mount. Quality product. Well worth the money, also got the low profile shields. Original cycra shields shown. Had to get longer triple clamp bolts ( went with stainless bolts and washers). Also had to put a slight bend on the handguard to fit, stuck one end of the handguard in a vice and pulled a slight bend. But overall an easy installation.
[IMG]local://upfiles/2770/0ADD924458134542B4A038EC66633D23.jpg[/IMG] Also there are no clearance issues with levers or brake lines, etc. Got them from the cycra website.
RE: CYCRA HANDGUARDS W/TRIPLE CLAMP MOUNT
Hi guys. I have a KLX 300 and usually hang out at Thumper Talk but occasionally check out what you guys do since our bikes are so similar. The Cycra triple clamp mount should work for you even with tall bars. It was originally my concern as well. I have big bar adapters, which raise the clamps 3/4" and CR mid high bars and the triple clamp mount works great. They are MUCH better than the bar mount. More room for your cables, lines and add on's and in the event of a crash no more rotating on the bars and having to straiten them out afterwards. Overall it is a stronger and cleaner install.
speedracer138
12-10-2007 03:59 AM
