Steering Stem/Triple Clamp
Wondering if anyone here knows whether the steering stem is interchangeable between the 03 04 model and the 05 06 model? I have an 03 and need to replace it, but only thing on ebay right now is 05 06 models.
Thanks,
Kev
Thanks,
Kev
RE: Steering Stem/Triple Clamp
I'm not sure if there interchangeable of not. i know the 05's and 06's are pretty much the same bike. so i'm sure the 03 and 04 model are the same bike too. I don't know if kawi changed the way the forks are between those years. maybe someone else on here can help you out better.
Looks like the part number for the 03 04 is 44037-1442 and the number for the 05 06 is 44037-0020. I've seen Honda parts that were identical except for paint have different numbers, so hard to say for sure based on different part#.
I think there is a smaller gar on the 05-06 models between the tripple tree and the tank. It looks like they mount the same way but the bases are a different sizes.
the 03-06 forks are the same diameter. The lower triple clamp looks the same but the upperclamp isdifferent. The space between the forks are the same on the 03-06 636's so I thik it will fit and work. The 03 in the picture is a Full Race Bike; Race tach & Ignition switch boss removed.
Update:
I found an 05 06 on ebay for $35 shipped, and figured I'd try it out. The bottom clamp is the same part, but the stem is different. For 05 06, it is shorter and has a wider diameter at the very top set of threads. The bearing/race diameters are the same as well. I'm going to look into pressing the stems out of the clamps and swaping them out.
speedracer138
12-10-2007 03:59 AM
