Crappy end to today's ride!
Old Nov 11, 2010 | 02:07 AM
  #31
Blackheart58's Avatar
Originally Posted by Nobrakes
Quick and dirty fix that will probably last the life of the bike - thread the hole with a tap and plug with a short bolt with a little gasket sealant around the seating surface.
Ooohhh. I wasn't aware the KLX guys can be as thrifty as the KLR guys... Great idea!
Old Nov 11, 2010 | 09:40 PM
  #32
mtnmac's Avatar
Depends on the thickness of the case there. If there was enough thickness, I would use a pipe tap and put a plug in it with teflon tape. This way you aren't depending on the surface of the case being perpendicular to the threads. It likely won't be after you tap it. Put grease on the tap so you pull the chips out with it.
Old Nov 12, 2010 | 05:08 PM
  #33
stumpjumper's Avatar
Even though this is one in a million mishap, I think I am going to take out the two bolts on my skid plate that go to the cross beam just to be on the safe side. You would still have the two clamps on the front that came with the skid plate and the two factory bolts in the back.
kawi750r
Jan 14, 2008 05:50 PM
beerman4679
Jun 26, 2007 02:19 AM
Icantrideabike
Jul 9, 2006 09:15 AM
ZX12Rider
Jul 7, 2006 04:26 PM
86ninja600rider
Jan 14, 2006 11:44 PM
