Changing wheel bearings
Old Jan 30, 2012 | 11:46 AM
  #31
Lockie666's Avatar
Originally Posted by EMS_0525
Instead of using the old outer bearing race, you can use a socket... if you have one big enough.
I was thinking I was rough using a socket :P
Old Jan 31, 2012 | 01:13 AM
  #32
brooksie's Avatar
Originally Posted by ol guy
It looks like a sealed bearing, I'm suprised it's so crapped up inside.
Sealed bearings keep lube in, not environment out.
Originally Posted by mustang
Nice work Dan! The bearings on my '06 were sealed on both sides. I wonder why yours were only sealed on one side. Regardless, it was time for yours to come out, lol.
One-sided seal will be fine because it allows gunk to leave the bearing. Sealed bearings are nearly impossible to lube. Personally, I'd use two sided steel shields in these applications. Just pop off one of the side sheilds. That way I could lay a good shot of water proof lube in there. One sided rubber sealed bearings are not easy to find and removing the seals could damage the bearing. I used to put bearings in every year when I last owned a dirt bike. And buy new spacers every year. These are light weight bearings taking a lot of shock.
I used to sell bearings for Motion and various other places. a 6004 2RS cost about $6. We used to get full list over the will call counter. I'll bet the local big account in town is paying about 15% over cost while you're about 60% or more. I suppose if you're gonna replace bearings once a year (not a bad idea in a dirt bike) Chinese bearings are good enough.Since it comes with the seals, I wouldn't try and beat Chinese prices for the stuff. Just get two sets and change them every spring, keep one set in the tool box. It's funny I have no problems spending hundreds on sexy mufflers and such but when it comes time to basic wheel turning maintenance items, it makes me gag to spend $80 on some good European bearings. Motor can sound real good but when wheels seize up, it only idles.
Old Jan 31, 2012 | 04:24 PM
  #33
ol'klx-er's Avatar
Nah! Standard operating procedure when removing/installing pressed in parts. Along with discreet use of hammer.
Old Jan 31, 2012 | 04:41 PM
  #34
It has to be a B.F.H. though.....
Old Feb 2, 2012 | 04:03 AM
  #35
Klxrelic's Avatar
Like they say....If it cant be fixed with a BFH...it must be electrical.
Old Feb 2, 2012 | 09:41 AM
  #36
I like the one i heard... "if you cant fix it with a hammer, duct tape, or super glue its a woman problem"
Old Feb 2, 2012 | 09:35 PM
  #37
If it moves and it shouldn't ....use duct tape.
If it doesn't move and it should......use WD-40
Old Feb 2, 2012 | 10:43 PM
  #38
brooksie's Avatar
Perfect!
Old Feb 7, 2012 | 04:52 AM
  #39
Ahh, shucks.
My bearings looked great. But fubar'd one on the way out. So, new bearings anyway.
But, this part is worn. It has a wear groove. How was yours?
Hit a bearing with the drive to get it out. Oh well.
Old Feb 7, 2012 | 09:12 AM
  #40
