Changing Tires
Old Sep 9, 2011 | 02:19 AM
KLXHunter's Avatar
Default Changing Tires
Is it even necessary to static balance or have the wheels and tires spin balanced jsut for off road application? Can you get away with some lube and tire irons?
thoughts
Old Sep 9, 2011 | 02:33 AM
Ynotride's Avatar
For offroad only then yes you will be ok without balancing. No one balances off road only bikes. If you are going to do any pavement at all I would suggest getting it balanced.
Old Sep 9, 2011 | 02:39 AM
I have never balanced any of the on, or off, road knobbies I have mounted. If you are talking about SF wheels / tires, then maybe get them balanced. Knobbies or DS tires, I wouldn't worry about it unless you have rimlocks installed.
Dan
Old Sep 9, 2011 | 02:42 AM
You're pretty much right about off road only bikes and balancing, but occasionally the front tire with a rim lock can definitely bounce a little too much without some balancing. Now, this can usually be accomplished by just adding some spoke-crimp-on or tape-on weights opposite the rim lock until the bounce goes away. Even off roading in the mountains of CO last month, I was at 50-60 mph occasionally on many straight, smoother sections. Before a rudimentary home balance, the front end would shake pretty good from an imbalance at anything above 35-40. Even though I use the Tubliss system, it still has a rim lock system. Some folks just install 2 rim locks, opposite from each other, but I wouldn't want to wrestle with 2 rim locks during a flat or tire change. Weights are easy.
Old Sep 9, 2011 | 03:22 AM
Ynotride's Avatar
I agree. I balance all of my tires both on and off road but it is not absolutely necessary.
I have a NoMar/Cycle Hill changer and balancer set up in the garage. Makes changing tires a breeze.
Old Sep 9, 2011 | 11:38 AM
RaceGass's Avatar
Balancing it for the added rim lock. This is what I found at a tire shop, any other options available?
Old Sep 9, 2011 | 01:45 PM
ol'klx-er's Avatar
Another recent thread shows the weights that crimp onto the spokes. Way less likely to get knocked off. And reuseable.
Found it
https://www.kawasakiforums.com/forum...55/#post454210
Old Sep 9, 2011 | 09:30 PM
Blackheart58's Avatar
I just use the spoke weights, and put on 2-4 opposite the rimlock. If it still bounces while on the road, I add or subtract one or more weights, depending upon how bad it bounced. Never had one I couldn't get to run smooth using this very, very crude method.
I sure like the setup pictured above, though. NICE!
Stashu
Oct 20, 2011 05:47 AM
olderthandirt
May 3, 2009 07:17 PM
Roadrage
Ninja ZX-10R
Apr 9, 2008 07:55 PM
petlam
Aug 11, 2007 08:01 AM
deej
Sep 11, 2006 04:43 AM
