CDI box from www.amrracing.com
Old Mar 5, 2009 | 12:36 PM
  #41
WestOzKLX's Avatar
Scavenging!
Old Mar 5, 2009 | 05:23 PM
  #42
cliffsta's Avatar
Cool beans, then I'm definately interested depending on the cost
Old Mar 7, 2009 | 03:23 AM
  #43
lcpl0331's Avatar
BUMP
Is there any news on this CDI yet?
Old Mar 7, 2009 | 04:40 AM
  #44
tremor38's Avatar
Originally Posted by LearjetMinako
Same thing, just worded differently. Just like some ignition systems have vaccum advance or electriconic through means of a TPS. CPS (Crank Positoning Sensor) is the most important for base timing. The effect is to advance the spark to get more power out of the fuel for a short amount of time.
As for the 09' KLX. I think Kawi did not install one for the 09's.
You are corrent on the 09 (no TPS).
As far as advancing the timing goes, the school of thought for low octane fuels -correct me if I'm wrong- would be to have some sort of knock sensor that retards the timing to avoid heat damage to the cylinder. That's why associating the TPS with low or high octane rated fuel doesn't make any sense to me....even if you're only talking about transients.
I completely agree with the 'vacuum advance' analogy though. Regardless of octane, I'd say it's there for that very function.
Old Mar 7, 2009 | 01:38 PM
  #45
LearjetMinako's Avatar
True. Just as there is a spark advance, theres also spark retarding (knock sensor). Also, not all vehicles come equiped with a knock sensor. The analolgy for higher octane fuel is because of the more advance base spark timing. Hence the reason why some vehicles say to fill with premium fuel only. If you can lower the base timing and only advance it when needed, you can run on a lower octane.
Back on target. If we do get an aftermarket CDI. It would be a great improvement. Especially if its programble. We would be able to surpass the 35*BTC that takes hold at 5k rpms and help increase the top-end performance. It would be even better if it includes an progam on the switch, so just flip a switch and go from stock timing to power.
Old Mar 8, 2009 | 12:29 AM
  #46
tremor38's Avatar
Back on target. If we do get an aftermarket CDI for 06/07. It would be a great improvement. Especially if its programble. We would be able to surpass the 35*BTC that takes hold at 5k rpms and help increase the top-end performance. It would be even better if it includes an progam on the switch, so just flip a switch and go from stock timing to power.
Agreed on the the aftermarket CDI... but that would be 25*BTDC for the stock 06/07CDI....not sure what the figures are for the 09. The service manual hasn't been corrected (general info section) in that regard for some reason. Myself and at least one other member of the forum have verified that with a timing light...all the more need for an aftermarket CDI though.
I'll say one last thing about 'vacuum advances' and say no more. The vacuum advance was never designed with lower/higher octane fuels in mind...neither was the TPS. The vacuum advance improved throttle response, regardless of fuel. The TPS was designed for the same thing, but is pretty much a gimmick.
If you want to talk about spill-over effects, you are reaching, but OK.
Old Mar 8, 2009 | 04:33 AM
  #47
Thrillbilly's Avatar
I don't give a F... about TPS
I wanna know about CDI
Old Mar 8, 2009 | 04:39 AM
  #48
cliffsta's Avatar
+1 on programming / stock-to-shock switch.
Old Mar 8, 2009 | 05:06 AM
  #49
novasteve's Avatar
Originally Posted by thrillbilly
i don't give a f... About tps
i wanna know about cdi
hillarious!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!:d
Old Mar 8, 2009 | 08:05 AM
  #50
tremor38's Avatar
HEY, it's a probably a long time till the CDI gets to the production phase, so I'm just giving the thread some filler material.
Say thank you!
