Carborator options?
Looks like the tm33/34 sits allot higher than the tm36.....
The tm36 is a bit shorter so the cables just go over the top like the stock CVK carb. it also has the throttle on the opposite side and the stock bracket works fine with the stock cable (once the routing is sorted out).
I got this carb because I’m planning a big bore and couldn’t pass on the opportunity…. Especially on one that had already been used on a KLX…… thanks again Back Trailin.
