Carb vent hose melted
Old Apr 6, 2018 | 06:03 PM
Dragon351's Avatar
Default Carb vent hose melted
That can’t be good…
so does this hose need to be a Unicorn pink spec hose or can I use the clear stuff from Lowe’s?
Old Apr 6, 2018 | 07:12 PM
I think fuel hose is preferred. If you do any deep water crossings, consider doing the "T" mod while you're in there.
Old Apr 6, 2018 | 07:28 PM
Dragon351's Avatar
Yeah, I just read about that… not stream crossing, yet.
I got plain ole hose for now, will hit an auto parts store sooner than later. thanks.
Old Apr 6, 2018 | 09:47 PM
Dragon351's Avatar
had to settle for black unicorn fuel line. Looks good.
Ok, took you’re advise and it’s sorted proper now. Thanks… t
Old Apr 8, 2018 | 05:09 AM
You don't need the exact factory tube, of course, but make sure whatever vent or overflow hose you get from an automotive source that it is fuel or emission rated. If it isn't, it will turn hard as a brick in short order. Automotive emission hose is usually preferable for vent tubes over automotive fuel line. Fuel line has to be thicker and stronger as it's exposed to pressure. Emission lines have little to no appreciable pressure generally, as they only have to deal with fuel vapors. They're thinner and more flexible.
Old Apr 8, 2018 | 02:18 PM
Dragon351's Avatar
I used fuel line because it's all they had at Advanced Auto that fit this carb. It seems tough enough and blends aesthetically with my decor/color scheme...
(what beautiful carb venting! I love the continuity of your hose palette... can I buy you a drink?)... t
Brandonbarrett
May 5, 2017 09:56 PM
alexgg
Jan 13, 2012 03:39 AM
OniNoKen
May 25, 2009 04:08 AM
08ninja250green
Ninja 250R
May 8, 2008 07:35 AM
shox rox ice
Jun 4, 2007 02:03 PM
