carb leaking gas
Old Dec 20, 2010 | 10:22 PM
dsather41's Avatar
Default carb leaking gas
Hey guys,
My buddy just gave me a 1995 KLX 250 and I am trying to get it running. He said it ran last year. However, when I put gas in it there is gas leaking out of the carb at the Float Chamber O-ring; is that a common part to go out. Once I get this fixed and get a new spark plug she should be ready to fire up. Also, is this part easy to fix or should I take the carb to a professional mechanic and have them do it? Thanks for any help you can provide.
Darrin
Old Dec 20, 2010 | 10:52 PM
If your sure its coming from that joint on the carb (check for cracked fuel lines, or an open petcock) pull the carb Making sure you pay attention to where every thing was before you removed it, (digital cameras are great for taking reference shots before dis-assembly) You may have a loose bowl or a cracked o-ring. Dig into it.
Dan
Old Dec 20, 2010 | 11:12 PM
David R's Avatar
I would turn off the gas and try to start it. It may fire. Run it till the carb is low and turn the gas back on. Its worth a shot. If it still leaks after a little futzing like tapping the carb with a screw driver and running it till the carb is dry a couple times, remove and clean or rebuild the carb, you will probably have to order the o ring gasket and a needle for the float.
Like the guy said above, look for dry cracked hoses, and the carb mount. No sucking air allowed.
A new spark plug is always good and cheap insurance. Fresh gas is your friend.
Let us know how it goes.
Old Dec 21, 2010 | 12:48 AM
TexasKawai's Avatar
If it sat for a long time the float could be stuck. I had this happen on another bike.
Old Dec 27, 2010 | 02:54 AM
dsather41's Avatar
I am on vacation, once I get back I will try these. I hope it works. Is the best way to get a manual by buying the $15 one online?
Old Dec 27, 2010 | 10:18 AM
David R's Avatar
Wink Look above
Look at the titles of the threads. One says 2009 manual, its FREE!
David
Old Dec 30, 2010 | 10:00 PM
Kirkland Jeff's Avatar
Good luck on the carb, and buy your buddy a drink or two. A friend who gives you a motorcycle is a true saint!
Arickrock
Jan 20, 2014 10:23 PM
ladyvorlon
Jun 1, 2010 07:30 PM
batts65
Nov 11, 2008 03:40 PM
LookN2Find
May 2, 2008 12:21 AM
1lowGMC
Ninja 250R
13
Oct 19, 2007 03:34 AM
