Carb leaking Gas
Old May 26, 2010 | 01:22 PM
ladyvorlon's Avatar
Question Carb leaking Gas
Just wondering if anyone know's how to troubleshoot and fix a leaking carb!
Gas is leaking out the overflow when the bike is running after idle. It is an old KZ440, has been ridin daily, and was rode yesterday morning, sat for 6 hours, now gas is leaking!
Any ideas on this????
Thanks so much in advance for any help on this matter! Nita
Old May 26, 2010 | 02:23 PM
94Ninja250's Avatar
Sounds like a float needle / seat issue. The float system is supposed to regulate how much fuel is allowed into the bowls. If something causes the needle not to fully seat, fuel will continue coming in, eventually running out the overflow. Sometimes they can be cleaned, other times they need to be replaced from wear. Either way, you'll have to dig into the carb and check their condition.
Old May 26, 2010 | 03:44 PM
ladyvorlon's Avatar
Thanks for the input, guess I had best find my manual and see what I can do, frustration is setting in!! LOL, oh well! Learn a little more everytime something screws up!
Old May 26, 2010 | 06:35 PM
Prom's Avatar
Sounds like Ninja has you covered, its a common problem and you should have no troubles getting back on the road. Let us know how it goes.
Welcome to KF!
Old May 27, 2010 | 03:42 AM
as mentioned by 94ninja ^+1 and verify float height at the same time. I have seen a float or two fuel log because they leaked and filling up with fuel. Good luck on the troubleshoot/repair.
Old May 30, 2010 | 12:09 PM
ladyvorlon's Avatar
Smile Figured it out...
Got the carbs off, got the floats bowls open and everything looked normal, and the specs were good too, but, replaced the needles anyways in both, put it all back together and it is running fine...THANK YOU
Couldn't find the needles for the KZ440, but matched the originals up with a set of Harley's, Huh, Kawasaki, and Harley use the same Carbs manufacturer!
Old May 31, 2010 | 11:11 PM
hahaha, go figure. Now my brother is going to ask me to fix his ride next. sssshhhh, I know nothing
congrats on the fix
Old Jun 1, 2010 | 03:16 AM
Prom's Avatar
Congrats on the Fix!
Old Jun 1, 2010 | 04:38 PM
ladyvorlon's Avatar
THANK YOU!!! Without your input on the issue, I wouldn't have known what to repair!
I can fix almost anything, just don't know how to diagnose it!
Old Jun 1, 2010 | 07:30 PM
Prom's Avatar
lol, I have the same problem. I can remove and replace anything but its hard to figure out what needs it. Thats why I stick around and try to help others, always learning.
Arickrock
Jan 20, 2014 10:23 PM
dsather41
Dec 30, 2010 10:00 PM
batts65
Nov 11, 2008 03:40 PM
LookN2Find
May 2, 2008 12:21 AM
1lowGMC
Ninja 250R
13
Oct 19, 2007 03:34 AM
