Carb Jetting
Old Mar 9, 2012 | 10:33 PM
durielk's Avatar
Default Carb Jetting
OK, 351 & pumper carb, I think I am pretty close on the main jet (130)..... but I am getting poor mileage. My pilot adg is about 1-1.5 out I think. I did a ATV trail with a healthy bunch of throttle twisting & only got 37.5 mpgallon. But this was not a difficult ride.
I was thinking of going to a vehicle smog test garage and have them put it on the machine..... would I get any usefull info out of this or does someone have a better idea.
The bike it running pretty good, but getting a definitive setting short of pulling the engine & finding a dyno is difficult.
351, 33 pumper, 3300 ft elev, stock everything else.
Old Mar 11, 2012 | 11:45 PM
durielk's Avatar
Did a little more research, seems like a wide band sensor & display may get some good info to see where the jetting is. I think I'll check into some of the local mech shops to see if they have one available.
I am thinking trying to get to A:F of about 14.7:1 under load.
Anyone ever use this?
Old Mar 12, 2012 | 12:04 PM
I have a dynojet wide band that I use for my 10r. Welding a bung in the exhaust is generally the most difficult issue in order to place the sensor. That should be included with every exhaust now adays in my opinion.
Old Mar 12, 2012 | 12:28 PM
linkin5's Avatar
You can run on a dyno and leave the motor in the bike and most of the places also graph your afr for tuning.
Old Mar 12, 2012 | 12:32 PM
that is true and about the same cost as a smog test
edit: I need to drive 4 hrs for the nearest dyno around here.
Old Mar 13, 2012 | 03:28 AM
durielk's Avatar
I ordered a wide band O2 sensor today.... interesting story to follow at the end of the month when I get back home.
Old Mar 30, 2012 | 03:06 AM
durielk's Avatar
OK, got the (Fuel to Air Ratio) wide range sensor installed and headed out to the biggest hill around I-17 south from camp verde. It took a while for the sensor to burn in as I was reading initially around 19-20. After burn in it went down to 13 WOT @ about 70mph-ish. Way to rich. MJ 135 (I thought I had a 130 in it, but not. Boys remember to write these things down as they are important).
Changed MJ to 125 and hit the road again, only I didn't go back to the big hill, the gauge will settle in pretty fast so picked a shorter hills around the house.... reading went to 16.5 ish on WOT in acceloration. The engine was stumbling a little on WOT. It pulled from idle very crisply though and at part throttle at normal speeds the reading were in the 13-15 range.
Therefore, I beleive 130 will be very close. I think I'll take the bike up to 7500ft elev and see how it goes next week though before I do anything, I am thinking of taking it to CO in August, so I may just live with it till then.
Putting the bike away I found the part in the picture... anyone know what it is? It is suppose to snap together around a cable/hose/wire? and then it may be a grommet? It may be off my bmw 650, if it is.. now I am worried.
The bike was dead when I tried to start it, had to bump start it. I removed the battery and topped off the water in it. I think I put too much in as after I started it, water was leaking out of it as it was boiling over. Oh well, it was really dry from the heat around here.
Old Mar 30, 2012 | 04:31 AM
jhoffy22's Avatar
Old Mar 30, 2012 | 11:02 PM
durielk's Avatar
jhoffy, I see the part you are holding up, but not very clear. The part I have when you get it hooked together has a smooth exterior cylinder shape like it is a grommet for a cable that passes through it, then it goes in a hole.
That is near the rear of the bike, where I was messing with it, but where does that thing you are holding up go?
redpillar
Dec 2, 2010 04:30 PM
klxrdr
Mar 26, 2007 07:09 PM
chris page
Oct 16, 2006 02:58 AM
gfoster
Aug 29, 2006 06:16 AM
bmwhd
Jan 17, 2006 08:41 PM
