CA Smog crap
Old Mar 1, 2012 | 11:30 PM
Brieninsac's Avatar
Default CA Smog crap
What if any smog equipment should I remove when I do the rejet?
Old Mar 2, 2012 | 12:07 AM
2veedubs's Avatar
All of it, unless you get inspected. Be sure to plug all the ports that are left open when smog equip is removed. Autozone has an assortment of vinyl Caps that make the job easier and last longer than the black rubber type. Dorman/AutoGrade 20 pcs. vinyl vacuum cap assortment includes 4 pcs. each size and color 1/8 in. yellow, 3/16 in. blue, 1/4 in. red, 5/16 in. white and 3/8 in. black (47397) | Vacuum Connector and Tubing | AutoZone.com
Old Mar 2, 2012 | 02:36 AM
punkenduro09's Avatar
x2
Old Aug 31, 2012 | 09:35 PM
trialstrails's Avatar
What did you do with the vent holes under the tank?
Old Aug 31, 2012 | 10:22 PM
Brieninsac's Avatar
I put on 2' tubes and ran them down to the bottom of the bike. There's another thread on what can be capped and tubed. I don't remember off the top of my head. They're color-coded so that should help.
Old Sep 3, 2012 | 05:09 PM
WHIP-N-DIP's Avatar
wait... i just re-jetted my CA model with dynojet stage 1, do I need to take out my smog ****???? really?
Old Sep 3, 2012 | 08:42 PM
Pogiboy's Avatar
You may if you want. I also rejetted with fmf pipe but I left mine on. Don't want to take chances with rangers around places I ride especially with a loud pipe lol. Glad you finally fixed your bike.
Old Sep 3, 2012 | 11:44 PM
WHIP-N-DIP's Avatar
oh okay.. but it doesnt affect anything if I leave it in there? i'm currently at DJ stage 1, fuel screw 3 turns out... and by 3 turns that means 6 half turns... so 3 360 degree turns.. I assumed thats what a full turn was!
Old Sep 4, 2012 | 02:57 PM
rgoers's Avatar
It still "affects" the bike. The thought is that no *performance* is to be gained by removing it. In my book - simpler is better. My SMOG stuff is long gone...
Old Sep 4, 2012 | 03:39 PM
Brieninsac's Avatar
No performance gain by removing the smog equipment but it does help your bike run a little cooler.
