CA Smog crap
What if any smog equipment should I remove when I do the rejet?
All of it, unless you get inspected. Be sure to plug all the ports that are left open when smog equip is removed. Autozone has an assortment of vinyl Caps that make the job easier and last longer than the black rubber type. Dorman/AutoGrade 20 pcs. vinyl vacuum cap assortment includes 4 pcs. each size and color 1/8 in. yellow, 3/16 in. blue, 1/4 in. red, 5/16 in. white and 3/8 in. black (47397) | Vacuum Connector and Tubing | AutoZone.com
Originally Posted by 2veedubs
(Post 464859)
What did you do with the vent holes under the tank?
Originally Posted by trialstrails
(Post 481239)
wait... i just re-jetted my CA model with dynojet stage 1, do I need to take out my smog ****???? really?
Originally Posted by WHIP-N-DIP
(Post 481321)
oh okay.. but it doesnt affect anything if I leave it in there? i'm currently at DJ stage 1, fuel screw 3 turns out... and by 3 turns that means 6 half turns... so 3 360 degree turns.. I assumed thats what a full turn was!
It still "affects" the bike. The thought is that no *performance* is to be gained by removing it. In my book - simpler is better. My SMOG stuff is long gone...
No performance gain by removing the smog equipment but it does help your bike run a little cooler.
