Brake Pedal Too Small
Old 04-24-2015, 09:37 PM
Rziskind's Avatar
Default Brake Pedal Too Small
The brake pedal on my '07 KLX250H is a little smaller than I'd like. In other words, I'd like it to be about 1/2 to 3/4 inch wider (at the point where the boot contacts the pedal) to make it easier to "find" by feel. It's not a major problem, just an annoyance. Has anyone else had this problem, and, if so, what did you do about it? (I mostly ride dirt roads and paved roads - some trails.) Thanks!
Old 04-24-2015, 11:46 PM
KLX25O's Avatar
Default brake pedal cover
I've looked also for such a thing and my google results were disappointing. seems no one makes a aftermarket brake pedal cover for this model.
Old 04-25-2015, 06:13 PM
Some guys have been very creative with the welder to make wider pegs. I think the same could be done with the brake pedal.
Old 04-25-2015, 08:44 PM
Brieninsac's Avatar
I saw his post Scott and didn't mention it thinking the welding mod for my foot pegs might not be strong enough for the brake pedal. What do you think?
To the OP, check this out, might be an option for you.
https://www.kawasakiforums.com/forum...options-40080/
Old 04-25-2015, 09:15 PM
I think a competent welder with good materials could do a fine job. We'll buy those cheap Chinese welded foot pegs from ebay and stand on them over jumps. Just a fraction of that force gets applied to a brake lever. Just don't ask me to do the welding because I can't!
I also think your work on the rear footrests is great. Have they held up? Even if the weld failed, the passenger should still have a good portion of their foot on the main peg.
Old 04-25-2015, 11:15 PM
I'd just bend the lever out about 1/2-3/4".
Old 04-26-2015, 02:06 AM
Brieninsac's Avatar
The funny thing is I think my wife has been on the bike twice since they were welded. So far so good!
Old 04-26-2015, 02:56 PM
Happy wife, happy life!
Old 06-05-2015, 04:07 PM
Rziskind's Avatar
Default Follow Up
I took the advice of several posters. Mike of Mike's RE-Cycles of Adams, Ma. made this little bracket and welded it on. It works like a charm. Thanks to all.
Old 06-05-2015, 04:24 PM
Looks great. Thanks for the follow-up.
Quick Reply: Brake Pedal Too Small
