Brake Pedal Too Small
The brake pedal on my '07 KLX250H is a little smaller than I'd like. In other words, I'd like it to be about 1/2 to 3/4 inch wider (at the point where the boot contacts the pedal) to make it easier to "find" by feel. It's not a major problem, just an annoyance. Has anyone else had this problem, and, if so, what did you do about it? (I mostly ride dirt roads and paved roads - some trails.) Thanks!
brake pedal cover
Originally Posted by Rziskind
(Post 520107)
Some guys have been very creative with the welder to make wider pegs. I think the same could be done with the brake pedal.
Originally Posted by IDRIDR
(Post 520136)
To the OP, check this out, might be an option for you. https://www.kawasakiforums.com/forum...options-40080/ |
I think a competent welder with good materials could do a fine job. We'll buy those cheap Chinese welded foot pegs from ebay and stand on them over jumps. Just a fraction of that force gets applied to a brake lever. Just don't ask me to do the welding because I can't!
I also think your work on the rear footrests is great. Have they held up? Even if the weld failed, the passenger should still have a good portion of their foot on the main peg. |
I'd just bend the lever out about 1/2-3/4".
(Post 520144)
Happy wife, happy life!
Follow Up
2 Attachment(s)
Attachment 7122Attachment 7121
I took the advice of several posters. Mike of Mike's RE-Cycles of Adams, Ma. made this little bracket and welded it on. It works like a charm. Thanks to all. |
Looks great. Thanks for the follow-up.
