Bike pops out of 2nd gear
Old Sep 11, 2006 | 02:13 AM
trey's Avatar
Default Bike pops out of 2nd gear
So I put on a 47 tooth sprocket and a new x-ring chain yesterday. Lots of low-end now, but after shifting into 2ng gear and reaching 6000 rpm, the bike slips into neutral- no klunk noise or anything- it just slips into neutral. All other gears are fine though. Clutch grabs nicely too. Any ideas???? thanks.
Old Sep 11, 2006 | 03:01 AM
KAWASAKIspeed's Avatar
Default RE: Bike pops out of 2nd gear
Yeah that i kinda a KLX thing on this bike. i have the 300r the same bike just bigger piston. you need to go to www.fourstrokeworks.com and look around there and you should find something like a shift star fear and that helps the problem. you just go to make sure that it is in gear. Good Luck.
Old Sep 11, 2006 | 03:07 AM
trey's Avatar
Thanks a lot!! I'm gonna order up a shift kit - we'll see if that helps. Thanks again!
Old Sep 11, 2006 | 03:44 AM
Make sure you tell Jerry this is for a KLX250S. Another member here, Kawi Wawi I think, ordered the shift star and while it worked mechanically, the neutral indicator is in a different position, or something like that.
Old Sep 11, 2006 | 05:21 AM
Kawi Wawi's Avatar
You should read through these two... I have done the shift star mod - ended up modding my own star gear.
Double snorkel & shift star fix installed
Shift star dilemma solved (sort of)
zx7blurr
Ninja ZX-9R
Jun 29, 2015 02:40 AM
rgoers
Apr 10, 2012 11:14 PM
red
Jul 29, 2011 10:49 PM
Sulli
Sep 9, 2007 03:03 AM
moparman48081
Sep 6, 2006 10:04 PM
