Big Bore kits
Old Feb 5, 2009 | 10:11 PM
RaceGass's Avatar
Default Big Bore kits
I would like to know before ordering which is more reliable: a pressed in liner type or a renikasiled big bore cylinder? There are many different displacements/liner types available, so I'm doing some researching. thanks
Old Feb 6, 2009 | 02:55 AM
cliffsta's Avatar
I'm no expert! But I would think that simply buying a KLX300 jug and associated parts from Kawasaki would be the best big-bore option in the reliability field.
Old Feb 6, 2009 | 03:31 AM
LearjetMinako's Avatar
Thats hard to say. Both have their advantage. Probably the best reliable big bore kits would be the 300 & 331. 350 is a sleeved and is new to the market.
Theres also many dicussens on the topic. Do a search.
Old Feb 6, 2009 | 06:19 AM
wapiti1's Avatar
I have a question, I have no idea if this is possible. Would a KFX 450 R cylinder fit this lower end?
Old Feb 6, 2009 | 06:32 AM
RaceGass's Avatar
Probably not. Different case opening first off. Not to mention alot of other factors including base stud pattern & top end brg/connecting rod compatability differences.
Using the search 14 pages under 'Big Bore reliability'. The last 6 wouldn't load.
Can the 250 cyl can be used or does a 300 cyl need to be sent to KK for the reboring/replating?
Thanks to those w/ experienced information.
Old Feb 6, 2009 | 09:29 AM
tremor38's Avatar
KK only bores the klx300 cylinder if you want their Nikasil coated 331cc kit.
You might be able to talk Marvin (KK owner) into boring the 249cc jug, but he would probably end-up sleeving it just as Bill does.
Old Feb 6, 2009 | 11:41 AM
Sid Post's Avatar
Why would a sleeve liner upgrade be inferior to to Nikasil or a 300cc factory top end? Lots of automotive and diesel engines use sleeve liners.
Old Feb 6, 2009 | 12:49 PM
The nikasil offers better heat transfer. Their is also the issue of two different metals expanding at different rates. But other than a few minnor pro & cons, it shouldn't matter too much. Sleeve liners are proven for decades upon years of street and racing.
mattyw
Oct 2, 2009 02:02 PM
punkenduro09
May 6, 2009 07:53 PM
maniac
May 26, 2007 12:36 PM
2006636r
May 13, 2007 07:11 AM
mattallica
Ninja ZX-7R
Jan 20, 2006 02:25 PM
