Big Bore kits
I would like to know before ordering which is more reliable: a pressed in liner type or a renikasiled big bore cylinder? There are many different displacements/liner types available, so I'm doing some researching. thanks
Thats hard to say. Both have their advantage. Probably the best reliable big bore kits would be the 300 & 331. 350 is a sleeved and is new to the market.
Theres also many dicussens on the topic. Do a search.
Using the search 14 pages under 'Big Bore reliability'. The last 6 wouldn't load.
Can the 250 cyl can be used or does a 300 cyl need to be sent to KK for the reboring/replating?
Thanks to those w/ experienced information.
Probably not. Different case opening first off. Not to mention alot of other factors including base stud pattern & top end brg/connecting rod compatability differences.
You might be able to talk Marvin (KK owner) into boring the 249cc jug, but he would probably end-up sleeving it just as Bill does.
The nikasil offers better heat transfer. Their is also the issue of two different metals expanding at different rates. But other than a few minnor pro & cons, it shouldn't matter too much. Sleeve liners are proven for decades upon years of street and racing.
