Big Bore kit
Old Jun 17, 2009 | 04:09 PM
leisman7's Avatar
Default Big Bore kit
Recenty got a 351 big bore kit from bill blue a part came with the kit that i have no clue what it is or where it goes. Anybody able to give me the good word?[IMG][/IMG]
Old Jun 17, 2009 | 04:30 PM
hercrigger's Avatar
looks like the blanking plate for the air injection system...
Old Jun 17, 2009 | 04:59 PM
Newblud1775's Avatar
Hi, new member here. I agree. Look on Bill Blue's site, page 4. He calls it a smog block off plate. So, if you've removed all the smog stuff, you can install this plate on the front, left side of the head, instead of cutting the hose and plugging it or removing the hose and capping the inlet.
Old Jun 17, 2009 | 05:27 PM
leisman7's Avatar
is this an option part? What hose would i plug and why?
Old Jun 17, 2009 | 08:08 PM
Try doing a search for "smog removal" or even "free mods". Either way, there should be a ton of useful results. Most of these members are totally awesome with the tech. info. Good luck!
Matt
Old Jun 18, 2009 | 08:03 AM
leisman7's Avatar
Is this part a must, and is it installed on the exterior of the engine? where is this hose located?
Old Jun 18, 2009 | 10:17 AM
tremor38's Avatar
It's optional...unless you are fitting a pumper carb.
There's a plate with a hose fitting on the forward part of the cylinder head. If you remove that plate, you can replace it with Bill's blank-off plate. The blank-off plate covers a reed valve to disable KCAS (Kawasaki Air Suction System) which dilutes your exhaust gasses with fresh air. You'll also need to plug the vacuum nipple on the CVK as well as the fitting where the hose hooks to the air cleaner.
The advantage of eliminating the KACS plumbing is that you can clean-up the area above the engine by eliminating a lot of hoses and your exhaust will run slightly cooler.
No performance gain what-so-ever though...your choice...unless you have pumper carb on the way...because most of them don't have a vacuum nipple to power the system.
Old Jun 18, 2009 | 10:44 AM
fgk228's Avatar
what country are you in, mine is an australian spec and doesn't have, but the american head i have on it now does. your bike my not have it, it was about a month b4 i figured out i did have that smog crap on it.
mattyw
Oct 2, 2009 02:02 PM
punkenduro09
May 6, 2009 07:53 PM
maniac
May 26, 2007 12:36 PM
Marty
Oct 27, 2006 01:33 AM
