Bernie's timing mod results ! (cue Hallelujah Chorus)
Old Nov 21, 2014 | 03:43 PM
  #51
Klxster's Avatar
So Richard, what is the bottom line on the timing mod ? Can you quantify the results? Do you think you've picked up 1 or more HP ? Do I need to plan to pull my flywheel ?
We ( old tuners) know too much advance can completely kill top end performance - you seeing that at all..?
Old Nov 22, 2014 | 06:40 AM
  #52
Richard Avatar's Avatar
I haven't noticed any loss in top end with the 34mm; meaning hi rpm. I don't know about top speed because the gearings so tight anyway, and I've never topped it out to see. I won't know any more until I test it some tomorrow with the 36mm carb.
Look into modifying the bracket that holds the pick up or slotting that bracket if you don't want to pull the flywheel.
Old Nov 28, 2014 | 04:16 AM
  #53
I now have two identical weight lightened flywheels; one with the 3mm nose extension to advance timing (on the bike now), and one that is unmodified except for being lighter.
I'll get around to a direct comparo between the two sometime in the future.
Simonm3
Jun 9, 2014 02:35 AM
David R
Apr 27, 2012 06:23 AM
Jul 1, 2011 02:43 AM
cliffsta
Apr 22, 2009 02:11 PM
txredneckmedic
Sep 20, 2006 09:48 PM
