Bark Busters ?
Old Jun 14, 2007 | 02:14 PM
vurtle's Avatar
Default RE: Bark Busters ?
These are the same ones I use. They are retagged by several companies. If you have the stock bars, you will have to cut about an inch off of each end (of the handlebar). Mine have taken a lot of abuse and lasted. The end handle bar mounts will have to be for the bar you have (steel or aluminum). You can use the aluminum mounts on steel if you have some properly sized rubber hose to fit over the mount and inside the tube.
ORIGINAL: KAWASAKIspeed
thanks everyone that has posted. has anyone wver thought of using these bark busters. (sorry could not get the picture)
http://www.enduroeng.com/item.asp?It...;Placeholder=0
I have amybe thought about these. thank you everyone for the advice. it will reallt come in handy.
Old Jun 14, 2007 | 03:22 PM
cwgoff's Avatar
Those EE handguards appear to be the same as the Moose guards that I had on my KLX. I did not need to modify the bars to make them work. I did have to point the guards a little down to clear stuff, but they seemed to work great. I really liked them. In fact, I have another set in black on the way to my house right now.
Old Jun 14, 2007 | 04:07 PM
YYY.GUY's Avatar
I installed the Acerbis Dual-Sport handguards with the integrated turn signals. I like how they look, but they turned out to be more flexible than they first appear. I've bent both clutch and brake levers just in simple low-speed get offs. I'll probably replace them next winter (I don't think they'll break before then, they just flex more than I was hoping.).
Old Jun 14, 2007 | 05:13 PM
Moose barkbusters with a Moose Raptor bend bar perfect fit couple inches higher and tough as nails.
Old Jun 14, 2007 | 10:54 PM
kpfetz's Avatar
I agree with Josh. Tusk hand guards from Rocky Mtn. are the least expensive and are very sturdy. I have them on my bike but don't have pictures. I did have to cut the ballends off but that is no big deal.
Pete
07 KLX250
Old Jun 14, 2007 | 11:24 PM
Joemama's Avatar
ORIGINAL: kpfetz
Pete
07 KLX250
I use the same as well
http://www.rockymountainatv.com/type...mp;webCatId=12
Old Jun 15, 2007 | 07:59 PM
KAWASAKIspeed's Avatar
Thanks everyone this really helps i will have to decide wich ones i want. i think i might go with moose.
Old Aug 24, 2008 | 03:50 AM
spgross's Avatar
Default Barkbusters triple clam set-up
Originally Posted by MaverickAus
I have (genuine) Bark Busters with the triple clamp mounting kit, if you bend or break these babies your going to break the bike. Even though this pic is not actually of the Bark Busters you can still see them.
close up of the triple clamp mounting
Cheers
Maverick Aus,
Which handlebars are you using with your triple clamps?
S0NIC
Feb 13, 2009 09:11 PM
horizonod
Dec 26, 2008 11:52 AM
mikey113
Jun 18, 2008 08:49 PM
Leem
Apr 25, 2008 02:13 PM
IchWarriorMkII
Jul 18, 2007 11:49 AM
