Any one else have a squeaky speedo hub?
Old Aug 9, 2011 | 08:48 PM
gonzo's Avatar
Thanks for the posts everyone.
Old Nov 15, 2016 | 09:37 PM
snappster's Avatar
Revival of old thread because I was afraid my wheel bearings were crapping out. Had me riding scared today. I will lube the speedo sending unit with wd40 tonight. If I don't repost here then it worked. I have a nearly steady high pitch squeal that sounds like it comes from the front end and stops as I go below a couple of mph. Bearings turn smoothly and no heat in hub. Brakes look OK too.
Old Nov 16, 2016 | 02:09 AM
Dezertdirt's Avatar
FWIW, mine did the same and would only fix temporarily with wd40. I took the wheel off, cleaned the mechanism, lubed lightly with wd40, put it all back together and it been over a year with no squeal. I ride dirt, so I didn't use grease as it would be a dirt collector.
Old Nov 16, 2016 | 11:21 AM
old man's Avatar
WD40? great if water is in the hub and needs displaced.
For lube use I like a silicone spray.
Old Nov 16, 2016 | 08:50 PM
snappster's Avatar
Used WD40 and paper towels to clean out the speedo unit and the dust seal. Lubed it with a fail amount of white Li grease. No squeaking today, hooray. I will have to wait and see how long it holds up. My question is what is the root cause? Wear? Dirt? Dry/No lube? Is the sound coming from the wheel hub on the dust seal or from the magnetic rotor spinning on the axle? I see no other relative motion in there.
Old Nov 20, 2016 | 02:13 PM
Josh128's Avatar
I just repaired the tube in my front and once it all went back together I started noticing a chirp when just barely moving/stopping. Like from 0 to 8 mph or so. Its very light though, not much to worry about.
I might try to shoot some aerosol lube in there though.
Road Kill
Jun 16, 2009 08:20 AM
tucaz#2
May 11, 2009 03:05 AM
dvillaronga
Apr 19, 2007 06:09 PM
taystyl
Mar 7, 2007 04:56 AM
eclipsehunter2001
Oct 26, 2006 12:24 AM
