Alternator /stator output
I understand that the output is somewhere around 200-220 watts. I have a heated liner that uses 28 watts max, the heated grips I am not sure. The grips are the type that have a grid that sticks to the handlebar and the grip slides over it, Hi/Lo setting. They came from a snowmobile dealer. Will I over tax the stater using one or both or these accessories? I do a lot of cold weather riding.
Thanks, Mick
Thanks, Mick
I believe the bike uses about 190 of the 220W just to run.
I rode all year for 3 straight years. I used heated gloves, helmet, and insoles (total of 20W IIRC) with no issue. I was also running a 28W LED light to brighten my way through the dark NH evenings when the sun sets around 4pm. With the light on I could see the battery voltage dropping. I just made sure to unplug a few miles before home to give the battery some juice back.
And speaking of being cold when riding, a small windshield is a great way to stay much warmer. Bar Mitts also helped a ton.
I've ridden in -25F and not much helps then. LOL
Good input, Maximus.
Mick - I use the same type of grip heater and for the one I use, the low setting just routes the power through a resister and doesn't actually save any energy. Just FYI that both high & low may be using the same amount of juice.
Having a volt meter is smart. You can get a digital one from ebay for a few dollars.
edit - my statement above is incorrect - low setting does save some power.
I don't agree with your assessment of the system. If the resistor was of infinite value, the load would be zero. Just say'in.
Interesting conversation. I caught all kinds of flack when I pointed out that bikes like the KLX had marginal charging systems when it comes to adding accessories. Seems they are.
I think it is possible to get a rewind for more power, but not sure.
Ahh, yes. Well done!!! My statement above is incorrect.
these are what I run: https://www.rockymountainatvmc.com/p...rip-Heater-Kit
I ran two 55 watt halogen cibie Oscar plus (very old school) lights with no problems on an ‘09 klx. I was gonna try a 100w bulb in one light but a member here Tremor advised against it as he had experience with over loading the electrical capacity on his bike. Baja designs rewinds klx stators for 130 watts output.
MaximusPrime
Jul 25, 2012 03:09 PM
