alternator/crankcase cover oil leak
Old May 2, 2014 | 11:03 PM
AndrewGMoto's Avatar
Default alternator/crankcase cover oil leak
Was lubing my chain when I noticed some silvery substance was near my shifter. It was seeping down from the alternator/crankcase cover. I'm assuming it's oil mixed with something. It was quite silver in color, and relatively thick. Last time I removed the cover was to install the Krieger Manual CC Tensioner, which was a while ago. This is the first time noticing any seep. Solutions?
Old May 3, 2014 | 01:52 AM
It's the "alternator rotor bolt cap," just for clarification.
I took it off, inspected. Oil looks good. Not dirty. Thinking the o-ring might just be lousy. I've already had to replace the oil filler cap's o-ring.
Plus, I can only tighten it so much with a quarter and a pair of pliers, before the quarter bends.
Old May 3, 2014 | 04:09 AM
GBAUTO's Avatar
If the o-ring is damaged then replace it. I always use a bit of rtv on the sealing surface just to make sure.
mikey113
Oct 12, 2024 02:54 AM
McLovinZX6R
Sep 8, 2012 03:37 AM
higgs
Jun 1, 2012 10:37 PM
cliffsta
Jun 6, 2009 07:43 PM
farmer
Sep 10, 2007 12:15 AM
